Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore coldspot ice maker not working
Water dispences out of dispencer but the ice maker has quit making ice (even with the tray empty and the bar doawn)??
    Genius:
  • 3,422 Answers
HI,
There is a valve at the back of the fridge that has two solenoids on it.
One solenoid is for the water dispenser and the other is for the ice maker.
You will need a meter to check the continuity of the solenoids.
There may be a fault in the ice maker.
Here is a link on how to check your ice maker.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 11, 2008
  • 3,037 Answers
Check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
  • Benjamin Patri
    Benjamin Patri Apr 18, 2008
    Were you able to fix this problem yet or do you need further assistance?
  • Benjamin Patri
    Benjamin Patri Apr 19, 2008
    Please let me know how this went, thank you for using Fixya and Good Luck
Kenmore Coldspot model#106.53359300 the ice maker not making/dispencing any ice, help?
Make sure the metal lever on the ice maker is in the lower on position. Check that the water valve for the 1/4 inch supply line is attached to the fridge and to the valve . Screw that water valve all the way in and then all the way out.
Jun 06, 2016 | Kenmore Refrigerators
There are very few ice cubes in the auto ice maker and when you empty those few, it takes a fdays to make new ones. I checked to make sure the ice maker is not locked, so it is not that anddd the water is...
Possibly need to lower the temperature in the freezer. Take note how much water is dispenced into the trays when a batched is deposited. If not enough possibly check the water if it is not freezing. ie insulate the open pipe area.
Aug 21, 2010 | GE Refrigerators
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
It's not making ice. It's not even getting the water flow in order to make ice but the water dispencer is dispencing water.
If it will kick a batch out if you add some water to it then your water valve needs replacement. if it has ice in it but wont spit any out then your ice maker is bad. Some nice repair pictures: HERE
Dec 31, 2009 | Refrigerators
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
The water will not come out of the dispencer.
There is one water valve but two solenoids, one for the icemaker and one for the water dispencer. If power is getting to the solenoid then replace the water valve. No power getting to the solenoid then the switch at the dispencer is bad.
Feb 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
370 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
