Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
Unit is properly charged, not moving when key switch is on and when it does it surges forward
