New PC woni't boot
Could you please help me fix this Pc I put the hardrive & the memory PC133 128MB 168 pin & the P4 2.0 CPU when I turn it on its beets one time over&over I know the parts are good that I put on I don,t have the $23.00 to ship it back How do you rinstall the drivers on thr motherboard
  • 156 Answers
There is a chance that the RAM is not placed properly or has dust ..
take it out, clean nicely, the edge which is inserted with a tissue Then reinsert it. If there are two RAM slots, then place the RAM in another slot and try.
continuous beeps are due to the ram not inserted properly or some loose contact in the power switch wires, which is not identifiable and correctable easily.
Posted on Apr 12, 2008
Tip
Windows instalation
If instaling windows vista you will need 1gigabyte of memory ram.
When instaling - hold delete or f2 key on keybord then select boot from cd-rom and then insert windows disc...
Always format hardrive for new instalations!
PC DESKTOP COMPUTERS
if you instal 2 optical drives or 2 hardrives check jumper pin settings at rear of drive. This is using old method IDE
TOP: should be set to master
BOTTOM: should be set to slave
SATA drives usualy automaticly take priority in sata order.
on Dec 04, 2009 | Computers & Internet
Flashing amber light on power button and won't boot but once out of 10 times???
If the computer shuts down after being on, also check that the CPU fan is seated flush on the CPU with thermal compound in between. If the CPU is too hot, the computer will shut down and not restart until cooled down a bit.
Apr 08, 2010 | Dell Dimension 8300 PC Desktop
Bad ram read
Try this, it can help you with your problem. Just follow this steps:
1. Open your computer casing where the motherboard lies in.
2. Remove the memory stick from the DIMM slot.
3. Clean the pins with an eraser of the pencil.
4. Put it back to where it belongs.
5. Find the bios jumper setting on the motherboard(refer to the motherboard manual if you don't know how to do it)
6. Reset the bios and turn it back to normal setting.
7. Close the the CPU casing be sure that the wirings are properly connected back.
8. Power on the computer.
Hope this could help you a lot. Please don't forget to rate me. Thanks..
Oct 27, 2009 | Gigabyte GA-5AX Motherboard
4400 dimension dell power light is light green solid, motherboard is solid green but cpu will not power up
Refix RAM memory.
Pull cmos cell for 10 minutes so all settings defaults.
Reconnect ATX power connector from smps to motherbord.
Also change your smps .SMPs is on back side of cpu on top it is square box.
Also check that cable from cpu power switch connected properly to motherbord power on/off pin.
You can test motherbord with power on /ogg pin ground power pin withg any metal it is in corner of motherbord.
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Dell Dimension 4400 PC Desktop
Laptop won't boot up. Power comes on, but it won't boot. First time it's ever happnened. Please Help!
I would take the hard drive out too see if you can get into the bios, if not. then take each of piece of memory intil you can get into bios.
First thing is too get visual on screen, once that happens then you can put hardrive back in too see if it hardrive related.
Jun 21, 2009 | Dell Computers & Internet
Putting the Computer Back Together
I need color of the wires that are in question. since some wires are not used. please make sure that the hard drive and cd roms are all plugged in and especially the fans are what I am concerned with.
Apr 27, 2009 | HP Pavilion xe743 PC Desktop
Drivers for MS-6389 Ver.1
Is it a Gateway PC?. They seem to be the only ones that use that motherboard.
If so have a look on their website.
You will need PC model or serial number.
http://support.gateway.com/support/drivers/ddaStep.asp?pg=2&Tab=All
Mar 22, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
Installing an old hardrive to a new computer
depending on the BIOS type, there must be a method to disable IDE-0 from booting. If no method found, try booting from floppy disc and then run setup.exe from CD. Try to find this in the BIOS settings, then enable it again after you have fixed the Windows.
Nov 25, 2007 | PC Chips (M791G) Motherboard
Asus P4S800-MX Motherboard video problem
The system speaker is usually a set of four pins and you use the outside pair to connect the speaker. You may need to go to the Asus web site to download the manual if you don't have it. Try to reset the bios either by shorting the appropriate pins or by removing the battery for a while.
Sep 06, 2007 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
