Question about Whirlpool LGR7646E Dryer
Spins but no heat
I have a gas dryer I put tennis balls in it to dry a down coat and it stopped working. Any suggestions? Could I have knocked something loose/
  • dnarielwala Jun 27, 2008
    I have the same problem. If somebody knows solution to this problem, please reply.
    Thanks
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
Spins but no heat - small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
Gas MaytaSpins but no heat - redarrow.gifbr />redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Posted on Aug 22, 2008
Lg gas dryer wont restart I dried 4 pair tennies in it must of shDLG2302w gas dryer down over load ? wont restart light in dryer comes on though
There is a thermal fuse in the blower housing tht is bad.. what makes it blow the fuse is a clogged dryer vent.. after u replace tht fuse make sure your vent is cleaned out. wht happens is the unit over heats and then blows the fuse..
Nov 25, 2012 | Dryers
M y gas dryer has slowly been taking longer to dry and finally it just spins for hours on end but will not dry at all.Any suggestions would be helpful
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 22, 2011 | Dryers
I wish to wash my Marmot down jacket- what products should I use and what is the best way to wash it?
you can buy specific detergent for down based products to clean and retain the insulation properties of teh jacket. I use NikWax down wash which works really well for my mountain hardwear down jacket. Follow the instructions which are usually:
put washing machine on clear cycle to flush all residue detergent out of the machine, use 1-2 capfulls of down wash and wash on a low heat 30-40 degrees. Then either air dry or my preferred method is to put it in the dryer by itself on a low heat with some clean tennis balls in the dryer - hey presto lovelly and clean jacket ready to go out and get mucky again
Jul 10, 2011 | Marmot Mountain Down Jacket
My king-sized sheets (only thing in load) are getting tangled in a ball in the dryer and not getting dry.
This is pretty common with lighter fabrics and is easily remedied. Put several new tennis balls in with the sheets to keep them from balling up. There are commercial products that do the same thing, but tennis balls are much less expensive.
Kelly
Mar 26, 2011 | Whirlpool Dryers
Is there anyway I can prevent sheets and blankets from getting wrapped into a ball as this prevents drying
You can put one or two tennis balls in with them. There are also dryer "balls" that stores sell but tennis balls work too!
Sep 15, 2010 | Samsung DV218AEW Electric Dryer
My whirlpool gas dryer will not heat. It only spins.
If the dryer won't heat but does run, it is more likely to be the gas ignitor assembly, assuming there is gas available to the dryer. If the thermal fuse was bad, the dryer wouldn't start at all.
Jan 06, 2010 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
150 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
