Question about Canon imageCLASS D760 All-In-One Laser Printer
Removing covers I am a former copier technician, now a pastor; we have an imageClass D760, well out of warranty. Do you know the sequence of removing the covers so I can get to the fuser unit, or am I going to have to purchase a service manual?
  • Anonymous Nov 04, 2008
    WHEN THE PAPER WAS GETTING FED TO COPY ON THE BACK SIDE IT GO STUCK. YOU CAN'T SEE IT BUT YOU CAN HERE IT?
  • 628 Answers
You may be able to remove the covers by removing screws in the fuser area. Canons are often puzzles, having to remove one panel before another. You'll just have to try one after another.It's usually not too much hassle; just notice the sequence for reassembly.
Posted on Dec 10, 2008
Sparks fly from cord connection (at the side of copier) when plugged into wall socket-
probably the rubber encasing isnt completely covering wire and sparks come from electric current touching metal. have that checked out proffesionally repaired
Nov 30, 2010 | Canon imageCLASS D760 All-In-One Laser...
Paper jam on a Cannon D760 copier
A technician who knows what he is doing is required to access the Canon fuser.
However, If you remove the glass on some later models there is an access hole wear you can get a long shank screwdriver down to the screw that holds the fuser in place. On some older models I have actually drilled a hole through the optics area to access the screw. You can get it with a stubby, but it is not fun. Getting the covers off is like working a rubics cube, good luck...
Jun 02, 2010 | Canon ImageClass D880 Copier
I have d760 cannon copier. finally removed the
hi,
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Oct 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Canon D760
You have one off possibly 2 problems.
1. The toner cartridge is defective. Try another and see if the problem goes away.
2. The fuser roller is defective. It has a teflon coating and after a while it either gets encrusted with toner and transfers ghost images or the image doesn't fuse properly.
I would try the first alternative. Let me know if it works for you.
Joe
Oct 26, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS D760 All-In-One Laser Printer system error
Check this link at Canon USA: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437
Sep 10, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Jul 03, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon imageclass d760 system error E000
Check out this link at Canon USA:http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437#SupportDetailAct
Jun 26, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon d760 system error e000
I used your "Best solution" and it worked
Thank you,Steven
Mar 04, 2008 | Canon imageCLASS D760 All-In-One Laser...
No power
well, i don't think there is nothing u can do to fix that on your own.
u wil need to get it looked at by professionals .
Aug 13, 2007 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS D760 All-In-One Laser Printer Logo
205 people viewed this question
old marine
old marine
