Question about LG WM2277HSW XL Front Load Stackable Washing Machine
LG Tromm WD 12270 RD washer and dryer
Hi!
18 months ago I bought this front load LG TROMM washer and dryer. From one year now it shows sporadically the tE error code (manual says "unplug and call technician").
Since I live in a remote area, no technician would come, so I would really appreciate your help. For your info, I regularly clean all the filters, the detergent and softner cartrige (including the water inputs to this compartment) and drain the machine from time to time, using the drain hose at the bottom of the unit. I also clean regularly the rubber sealing between the drum and the body of the washer.
About one year ago, the tE error code showed up and the machine stopped in the middle of a washing cycle. I disconnected it, then plugged it in once again - the error code dissapeared and I could finish my washing. Since then, this code appeared sporadically, but lately it appears all the time. I can re-start the machine by manually rotating the drum and/or changing the cycle to cold water, so I can eventually finish washing the load.
However, the problem won't go away, so I would like to solve it once and for all.
Any ideas what to do?
Thanks,
Lia
Hi, I don't know how to fix your problem, Lia, unfortunately, BUT wanted to say "Thank You!!" for mentioning that you can get the washer to run through the cycle by rotating the drum and switching to cold water wash! We'd tried unplugging, leaving it unplugged overnight even, but the code/beeping started immediately after plugging back in. I'm kind of longing for an old-school washer right now, thinking of all the things that can go wrong with the newer digital-age computerized ones :-) If you see this, please share what you did to solve your washer problem! Hoping it's not too expensive to fix...or I should say to GET it fixed :-\
Posted on Jun 08, 2010
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on ยท LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
My lg tromm front load washer stops at 37 minutes
check the drainage pump or electronic board is faulty
Oct 20, 2014 | LG Tromm Front Load Washer And Dryer Set
Lg front load washer with a tE error code and switched the thermistor that was located when I took the top off the washer and it ran two loads fine but code is back...I noticed online they keep saying the...
As many suggest, the tE error means there is a thermistor error. On my machine, simply unplugging the machine, tipping the machine backwards (careful! ... I put a few blocks under the front legs so I could work under the machine)...and the thermistor was under the drum, with a 2-wire lead going to it. It was easy to unplug, tighten the plug (squeezing the connector), plugging it back in. The machine has now worked fine ever since this simple procedure with no failures.
Oct 27, 2013 | LG WM2688HWM TROMM SteamWasher
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,474 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
