Gigabyte GA-945GZM-S2 Motherboard Logo
A
Anonymous Posted on Jun 11, 2010
I wanna get the ethernet controller driver where can I get it???
Anonymous
Level 2:
  • Expert 269 Answers
  • Posted on Jun 11, 2010
Anonymous
Expert
Level 2:
Answers
269
Questions
0
Helped
95062
Points
701
you can download a copy for your Ethernet driver from here click to download chose your operating system and download.
Thank you for using Fixya.
Regards
Manish
Ethernet driver is missing and i wanna to overcome the problem
I cannot give you the link to download the LAN driver because you did not provide details of the make and model of your laptop.
When you give me the details then I can assist you.
Not detect ethernet controller for dell optiplex 210L i looking for the driver
You want to try and see if there is a driver update for the ethernet controller. Go to: START> RIGHT CLICK "MY COMPUTER"> then PROPERTIES> DEVICE MANAGER> NETWORKING> ETHERNET PORT. You can roll-back the driver or you can try to update the ethernet driver using Windows Update Program. Make sure the driver is located in the device manager system and windows recognizes it. Your Ethernet Controller is a discontinued product. If you can't seem to get the ethernet controller to work and don't have the Floppy Disk Driver for it, then I suggest replacing it with a new stand alone ethernet controller that uses PCI or PCI-E ports. You can find some at Best Buy and Staples. They are easy to install and they don't use your motherboard memory and are not integrated on motherboard. I hope you find something that works and you can get back online again.
When installing the USB2106S Ethernet Adaptor I get the error "Failed to copy files to MosUmac folder" The installation then fails.
Hi Chris,
I see that you are having problem installing the driver for your USB Ethernet adapter. You can try to download the driver using another computer in the link that is posted below. Save it on a thumb driver and double click on the application. You might wanna make sure that you have an extractor for compressed files (rar) like winrar. If you don't, you might want to include downloading Winrar in the thumb drive as well and install it in your computer.
USB Ethernet Driver
Winrar
I have wireless connection but can't connect to the internet. I can however connect my ethernet cord in and get on the internet that way. What could be the problem
you may wanna check if the wireless switch is on or off (usually located on the front of the pc and it needs to be toggle on the right side)..if not work you may wanna try to update the wifi driver under device manager..
hope this helps :D
Cannot find ethernet driver for Acer Aspire T180 athlon 3800 so that i can get online.,
goto acer .com support. and download the driver form a working comp, put it on a usb then stick the usb in the non working comp. go into device manger, click the "?" and update it should do what your wanting it to do by itself and get you online, you might wanna disconnect the cat5 cable from the ethernet before starting the update
4helpful
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
2helpful
2answers
1helpful
4answers
Please, ethernet controller issues.
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
3helpful
Ethernet Network controller
use driver updating software ie driver magician. it scans ur outdated drivers and automatically downloads drivers that r compatible for your computer.............
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
