Question about MSI 865PE Neo2-V Motherboard
Power for a split second
Hello. I just transferred my mobo/cpu combo into another case with the case and the power supply being the only new additions of hardware. Now my computer only powers on for a split second and then shuts off- no display or anything. the cpu fan starts up and then stops and the power LED for the case turns on for just a moment and shuts off again.
  • Micah Gregorio
    Micah Gregorio Apr 12, 2008
    the motherboard was being shorted by touching metal on the case. i took out the pci/agp components, put them back in and reseated the motherboard. All is well.
    Sergeant:
  • 209 Answers
Dear migregorio
I think that your problem is either to do with the power supply, not putting out the same amount of power as your previous PSU, so therefore i reckon to start checking your power supply ratings and usage ratings on both PSUs and then evaluate whether the new one is the right one for your machine, it could be beneficial to try using your previous power supply in the case that you have transferred the components into. If this still has the same effect as what you are getting then i would guess that you have either a short circuit from the motherboard to the chassis, or your PSU is not grounded, and therefore an open or incomplete circuit is formed. This will explain why you only receive power for a split second.
I hope that this information helps you for now, and if not, please mail me back here and i will endeavour to respond to you ASAP.
Im normally on here 24hrs a day 7/365 days a year in order to answer various questions and comments, so if you do require further assistance on this or any other matter please feel free to contact me.
Once again, I hope this article proves to benefical and look forward to hearing from you soon
yours sincerely
oz
Posted on Apr 11, 2008
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Won't boot. mobo power lite is on. fans power up for split second. have check everything. cpu is new. checked ram. all devices. No lose connections. reseated cpu twice.
It sounds like a problem with the power supply. Do you have another one you can test with? You could also purchase a power supply tester.
Here is a link to the power supply testers on Amazon. There are all sorts of prices and features so it really is a personal preference which one you get.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=power+supply+tester
Mar 08, 2011 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
I have a PC that died completely - not reacting to the power switch at all. Over the last few months I've replaced the PSU and, more recently, the MOBO and CPU, but it's still dead. I ordered a new case...
connect the positive lead of a multimeter to one wire from the switch, connect the negative lead to the other wire. Set the meter to ohms. Push the button, does it go to 0 ohms? Let go of the button, does it go to infinite ohms? This should tell you if your switch is working without having to take it out of the case.
Feb 23, 2011 | Cooler Master Ammo 533 No Power Supply...
PC power down after 3 seconds power on. Power
pull out the cpu chip and see if it comes on or beeps,
If it dont its the mobo.
Sometimes the mobo and the cpu go bad at the same time, a bad cpu can kill the mobo
Apr 15, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Oct 31, 2008 | Tyan S5396A2NRF Dual LGA771 XEON5000 5100...
Problems with P35neo2
Check your M/board manual for setup if it should have an 8 pin power connector you will need a power supply to suit it if you continue trying without it you could also be up for a new motherboard and CPU
Aug 05, 2008 | Super Flower Computer Super Flower Cable...
Wont post and buzzing noise
Don't mean to butt in here but I'll bet the 4 pin_ATX 12v connector is not connected to the board. That 4 pin_ATX 12v connector give's the CPU it's power. Without is the system will not boot. Some boards will give off that weird sound you are hearing.
Feb 29, 2008 | Computers & Internet
Computer will power up for three seconds then shut down
Had the same problem on a few motherboards, check your capacitors very closely. If they are rounded or split on top they are bad. You can change the capacitors with new ones to fix your problem but it often ends up costing as much as buying a new board.
Nov 08, 2007 | Intel D101GGC Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
MSI 865PE Neo2-V Motherboard Logo
106 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
