Question about Minolta CF2001 Copier
C0206 code meaning
C0206 has come up - I have emptied the excess toner thinking that was it but the code still comes ip
  • kingman813 Apr 18, 2008
    many thanks for the hep. Its was indeed a waste toner build-up.
    I have emptied the waste toner, but the C0206 still comes up, so I am assuming that I must do a reset and do not know if or where there is a rest button or code.
    Can you help please. thank you for the help so far it was invaluable.
    Kingman813
  • brian c
    brian c May 11, 2010
    Code C0206 is a black drum unit corona malfunction.
    This may simply be toner build-up, a staple / paper clip, etc on the corona unit, or an electrical malfunction.
  • 24 Answers
Press buttons in the exact order, utility-meter count-stop-0-0-stop-0-1. you are in service mode. now you enter counter - reset counters, or trouble and see the meaning of C 0206, if I well remember it's a corona wire problem! you can either change the wire and reset the error code or, in case that it wont work, to measure the tension at wich the corona charges!, probably the first thing will do the job!!!
Posted on Nov 03, 2008
I have a Epson Aculaserb printer C1900 and i keep getting a message ( M Toner Cart out ) what does this mean
I would think one of your colour toners is
empty,the lid has come up (push it down ) or the cart
has come off rail.
LUCK
Dec 17, 2014 | Epson Office Equipment & Supplies
Hp laserjet 1320 toner empty?
you might try a recycled cartridge and have a lot less invested.Sounds like your cartridge is empty.Is print quality bad or light?
Mar 20, 2014 | HP LaserJet 1320 Printer
I have an MFC Brother printer and I cant copy or print...it says waste toner full??? How do I fix this problem?
What model MFC Brother Printer do you have? The waste toner is left over toner from each print or copy that isn't used. It collects in a different spot in each printer. Usually the waste toner container is with the regular toner cartridge. The printer is able to detect when the waste toner is full by a light sensor in or near that container. Sometimes excess toner collects on the sensor itself and causes it to think the waste toner is full when it actually isn't. Try finding the waste toner container and empty it or replace it. clean the sensor that is on or near the container. it is likely a small black plastic piece that has 2 or 3 small wires coming from it. The model of printer will help to identify where the container is.
Jan 14, 2011 | Office Equipment & Supplies
Toner
when the toner light comes in and the status is red, it usually indicates that the toner is about to be empty or is empty.
if status is green and the toner light is blinking it means its low
Jun 17, 2009 | Brother HL 5170DN Laser Printer
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
C7980 error code
It means your waste toner is full. Pull the process unit and look on the each end for a screw on each side that are recessed. Remove them and take out the small panel that acts as a plug. Empty the excess toner out of each side and put covers back on. Then put your process unit back in go into the service mode. Press stop/clear button hold down, while holding press start button keep holding both buttons and then press the left side exposure button..hold all 3 buttons for approx 20 seconds till U comes up and starts flashing. Use the buttons under the display and put in 100 and press start to reinitialize the developer. After the unit stops initializing turn it off and on and you should be all set.
Apr 03, 2009 | Copystar CS-1500 Copier
Kyorcera FS1030D - error light sequence
Dave,
You need to empty the excess toner reservoir in the front of the process unit.
Front as in the other end to where you put in a new toner.
All you have to do is open the side panel and empty all the toner out.
That should fix your problem.
Sorry to give you all the instructions like this but people still open up the toner end and have a lot of fun putting it back together.
Enjoy
Dec 15, 2008 | Kyocera Mita FS-1030D Laser Printer
UNKNOWN CODE
when ap code is coming add toner. when the toner is empty this code displays.
Nov 23, 2008 | Kyocera Mita KMR-1810P Laser Printer
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
730 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
