Question about Power Acoustik PS2-1600 Car Audio Amplifier
Amp getting really hot
I have a power acoustik PS2-2200 amp and its hooked up to a Almani S5-12" and after about 3 min my amp gets really really hot. The amps RMS is 900 watts and the subs RMS is 800 watts. I was wondering if the amps RMS has to be less than the subs RMS or if the problem is something totally different? If someone could please help me out in anyway that would be great.
Thanks!!!!!
  • 631 Answers
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Posted on Apr 11, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: amp getting really hot
If depends on what the amp is rated to run. If it is only rated to run 2 ohms x2ch then it can only run 4 ohms x1ch. If you run it at 1 or 2 ohms that is too low, too much current, and it will get hot and eventually blow up under hard use. Some quality amps can live that way, and it depends on the sub and what frequency you are running it at. For normal use I would not recommend it. Wire to sub at 4 ohms x1 (or 2 ohms x2ch) for that amp if that is what it is supposed to be at, I'm not sure from your description. Also enhance cooling of the amp if you can, I run fans on mine if they have a heat issue. Warm is one thing, hot is another and not good for amp.
Posted on Apr 22, 2008
Amp shuts off then on
It's getting so hot that it's going into thermal protection. Turn down the gains of lighten the speaker load. The more speakers that hook up to it the more power it will put out causing the amp to overheat. Eventually it will burn up some of the output Mosfett Power Transistors.
Apr 01, 2013 | Power Acoustik Car Audio & Video
'"hi i have a power
The refurb may not have been complete
Mar 24, 2017 | Power Acoustik Car Audio & Video
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
My amp protection will not turn off i tryed almost everything?
i wish i can chat to you live so i can ask you qestions about your amp but to figure out what section of the amp might be fried it could be the power supply section could be the out put section or the in put section but i would try process of elimulation try unplugging your rca jacks and your subs unhook to your amp just the power hook up and try powering it but if the protection light steel comes on then try to remeber the last time your amp was working good and playing your subs was your amp getting hot if so you probaly fried your out put chips and not telling what else next question was you just hooking your amp up in your car and acually touch one of the power wire to the ground on your amp this happen to my friend and fried the power circuit relay chip on the power supply thats all the advice i can give but usually when the protection light comes on and you got every thing hook up right something fried
Oct 29, 2009 | Power Acoustik LT-980/2 Car Audio...
Amp started skipping when first installed now not at all!!!
http://www.fixya.com/support/r2656152-amplifier_going_into_protect_mode
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Jul 16, 2009 | Power Acoustik Sapphire SP2X-1200 Car...
Protection light stays on even when everything is disconnected.the output transistors are turning red hot instantly and it has a 20 amp draw on it.while it is hooked up to a power supply with no sound...
there is a short somewhere one your board that is putting all the load on your output transistors follow the traces on the board both ways to find the short
Jul 05, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
Amp and subwoofer problem
try using an ipod or mp3 and hook it up directly to the amp input section-if its lit up and you get sound then youre not getting signal from your deck and youll have to track that problem down at the deck-if you still dont get any sound by connecting directly into the amp inputs then you may want to check all amp settings and be sure that your set up right and if it has external fuses make sure that they are all good and if it still wont give you any sound than take it in and get it checked out-hopefully its just not getting any signal cuz if its the amp then sorry to hear it-but good luck
May 21, 2009 | Power Acoustik BAMF2000/1D Car Amp
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Oct 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Power Acoustik PS2-1600 Car Audio Amplifier Logo
249 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
