Question about RCA F36668 36" TV
TV turns on & off by itself. Channels also change by themselves.
My TV seems to be possessed by something. It turns on and off by itself. Once it's on, it won't be long before the channels start changing. At first I thought I was sitting on the remote. It wasn't that. I took the batteries out just in case it was the culprit. It's an RCA 36" F36668 TV. Can anyone explain?
  • Anonymous Apr 30, 2008
    My television also just stopped working. It just clicks when I try to turn it on with the remote or at the set. Have you had this repaired yet and if so, how much did it cost?
    President:
  • RCA Master
  • 1,779 Answers
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
Posted on Apr 11, 2008
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a Samsung LN55B650, and cannot use the remote to change channels, hav eto use cable remote. I change to TV mode, and program in channels, but that option is not available once I switch to HDMI2,...
OK the cable box remote is the only one that can change channels in this case. because you are using the tuner in the cable box not the TV.
all you need the TV remote for is to turn the TV on and off and turn the sound up and down. if you used the cable input on the TV then the tv remote would be used to change the channels.
Dec 25, 2010 | Samsung LN55B650 55 in. LCD HDTV
Changing channels
A common issue with this model is the control key board (the key input board that has the buttons on the cabinet of the TV).
This board can cause a lot of issue ,from changing channels by itself,to intermittent shut off, also sources cannot be switched or they switch by themselves.
The less common issues would be the remote eye or the main board.
If you give the full model number and the product code from your TV, I can give you the part numbers.
Apr 01, 2010 | LG 22LG30 22 in. LCD HDTV
19LG30 TV issue
Call LG and schedule a service call with a local tech to properly diagnose the system. Sounds like it's a main board issue, though.
Feb 16, 2009 | LG 19LG30 19 in. LCD HDTV
Our LG 37LB1DA is scrolling through channels
I have seen problems similar to yours in the past. Several causes can make the channels change by themselves. Some corrosion on the main board near the channel up/down switches for one. The next common cause is that the EPROM may be failing or a fault with the main control processor. A good test to see if the EPROM is having a problem is to program in all the channels off the cable and then unplug the TV over night and then plug back in the see if any channels are missing.
Jan 17, 2009 | LG 37LB1DA Television
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
TELEVISION HAS MIND OF ITS OWN
It's possessed just like mine! ;) So I have no idea besides a basic check:
Does the tv do this even when you take the batteries out of the remote, and block the sensor in the tv with tape or something to make sure its not someones remote doing it?
- Dave
Dec 28, 2007 | Televison & Video
TV changes channels itself
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
Apr 01, 2006 | Bush WS6671 28" TV
Channels change by themselves ??? please help
its mosy likly the remote control sensor inside the set. had the sam problem a couple of times already. I'll post the part # when I can find it
Mar 27, 2006 | RCA P52955 52" Rear Projection Television
RCA F36668 36" TV Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
