Casio KL7200 label maker Message: DATA ERROR! when turned on Pushing Esc permits entry of label info Pushing Print results in DATA ERROR! message and no printing. What data is in error, how do I correct the problem?
  • Anonymous Aug 07, 2008
    same problem
  • kernell Sep 07, 2008
    The screen indicates "DATA ERROR" and doesn't permit printing of labels?
    I have attempted to use all of the buttons to correct this malfunction however nothing has improved.
    What advise do you have?
    sthaw@mac.com
Press any key other than "on/off" to clear the DATA ERROR off the screen. Then, the screen will say "initial". Press "set"
Posted on Jan 12, 2009
  • Kristina Tina
    Kristina Tina Sep 02, 2014
    It worked, thanks;)
Shows ERR when turned on
Hi, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Mac =)
Dec 28, 2013 | Casio KL-60 label maker
Shows ERR when it is turned on
Hello, If you can't get it to work, try to do a factory reset.
Hope this helps.
Best wishes
Mac =)
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
Jul 30, 2012 | Toshiba TEC B-572 Printer
My E Z label casio printer KL-7200 keeps saying DATA Error and low battery, and it won't go to the symbols and won't priint anything even after I plugged it in.
When it says "DATA ERROR", press any key. Next, you should get prompted with "INITIALIZE?". The key to solving this problem is to press the "SET" key. Turn off your label maker, then turn it back on. Should be back in action now, enjoy!
Oct 31, 2010 | Casio EZ Label Printer
I have this EZ label printer (says Label IT! and KL 780). It has worked before to make simple labels, but now when I try to print anything-anything at all- 'data error' comes up on the screen. What do I...
Hi. I can help you. Remove all of the batteries. Let it sit for two minutes while it resets. Reinstall the batteries being careful to honor the polarity. Turn it on and you should be up and running. If you still have the problem return it.
Jul 13, 2009 | Casio KL-780 Thermal Label Printer
I need to change font size on my label maker
http://support.casio.com/manualfile.php?rgn=1&cid=005003001
Apr 23, 2009 | Casio Label Printer
DATA ERROR 40!
Hello
Here is what the manual says. It might help you decide what to do next.
Mar 16, 2009 | Casio Algebra FX 2.0 Calculator
I have a casio kl-60 EZ-LABEL Printer my batt was low tried to print and labeler said ERR. Changed Batteries still said ERR. Please help lost manual. Tried to find manual online. would be nice to have.
to reset memory
1. Make sure that label printer is off
2. While holding down the PRINT and ESC keys, press ON?OFF to power on.
3. KEEPING PRINT and ESC held down, release the ON?OFF key only.
4. Release PRINT and ESC keys.
5. Press SET to initialize the Label Printer or ESC to Abort
http://ftp.casio.co.jp/pub/world_manual/ds/en/KL_60_E.pdf
Aug 14, 2008 | Casio Computers & Internet
Error
turn off your printer press PRINT & ESC at the same time, prees on/off at same time then release the PRINT & ESC botton then press SET
Apr 27, 2008 | Casio KL60SR Label Printer
1,956 people viewed this question
jasbo
jasbo
