White lines going across the screen - Computers & Internet
  • 156 Answers
THere are two possibilities
1. problem in mother board
2. problem in monitor
To make sure if possible connect your CPU to another monitor and see if all is fine. If the other monitor works fine, then your monitor has th problem
if the other monitor also has lines, then the mother board's video card has prob.
Also check the connection wire between the CPU and monitor that there is no loose contact or any cuts or damages in the wire
Posted on Apr 12, 2008
Akai 13" TV/DVD Combo CTD-1390 White Lines going across the screen with enlarged images on screen.
Retrace lines. This fault is called so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to CRT screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2014 | Akai Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
White line going across screen of i pod classic
U HAVE A SCREEN IPOD CONNECTION PROBLEM, U  HAVE TO GO TO AN APPLE STORE TO FIX IT
Nov 28, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Vertical white lines across screen
whatever brand your tv is go there .com maunals it should show u what u need to know
Jul 14, 2008 | InFocus ScreenPlay 61" Rear Projection...
White line on screen
Usually a white line straight across the screen indicates that the LCD screen has a bad row. There's not much you can do about it I'm afraid.
If you're mechanically capable, you can go to e-bay and pick up a non-working unit (for parts) and replace the screen on your working unit. I guess it depends on the cost of the unit. You might just be better off using it as is.
Mar 27, 2008 | SanDisk Sansa e260 MP3 Player
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
