Gateway M-6750 Laptop power issue
I recently got a M6750 and it worked for a while but now when i plug it in it neither charges nor powers up? can sombody help me?
  • 1 more comment
  • Xetsumei Apr 12, 2008
    thank you for the advice but i have fixed it on my own, i opened it up and found that one of the conections to the board was severed, so i re connected it and its fixed. thank you though im sure your advice will help many others like me.
  • vethost Jan 27, 2009
    I have the same problem. It worked for a few months then died. The power adaptor has no LED.
  • Anonymous Mar 11, 2009
    when I press the power button, lights blink for 3 seconds then nothing happens. tried leaving battery out. same result.
  • 42 Answers
First try this: Unplug the laptop from the AC adapter (very important). Then take out the laptop battery and place it back into the laptop after a few seconds. Try powering on the computer. If that does not work, then continue reading.
If there is a LED light on the gateway power adapter check that it turns green when the adapter is plugged in. If it does not turn green (assuming there's a light there at all) then your power adapter is bad. There are a couple of different places to go from there. If the computer is less than a year old take it to geek squad at any best buy to have them send it into service under manufacturer's warranty. If it is not less than a year old try buying a universal adapter from Best Buy to see if that works (which you can return without penalty if you wish). If that does not work then your motherboard is bad. The cost of repair would probably come close to the cost of a new laptop.
Posted on Apr 12, 2008
My Gateway m6750 crashed and I need to get an operating system back on to the new disk., I do not have any backup. but I do have another m6750 that works great. Is there a way to back up the operating sys...
I am assuming the operating system is Windows Vista ?
Windows has a mechanism that detects the hardware on your computer and will most likely get upset that it has been copied onto another P.C. Most Windows O/S on Laptops are OEM licensed which means that if the P.C is non working the licence stays with the now non working p.c.
suggest trying to recover crashed hard drive from hidden recovery partition
then try getting a recovery cd for your particular serial number and model number from
to use on your new hard drive
Jan 17, 2018 | Gateway M-6750 PC Notebook
Gateway Laptop(MODEL M-6750): The power button keeps flashing blue and so does the wireless signal. I've tried removing the battery, holding the power button nothing changes.
Does it do this when it is plugged in? Try to power it up with no battery, and see if it acts differently, it may be a battery issue unsure. Is the computer working normally except for this problem?
Jun 10, 2011 | Gateway M-6750 PC Notebook
My Gateway M-6750 laptop was working last night but today when I tried to turn it on the power button light flashes on and off and nothing else. I have unplugged it and removed the battery and held down...
Remove the main battery and the power supply charger, allow a few minutes to get rid of any residual charge. Replace the battery, press power, if there is no change, remove the battery. Now plug the power supply back into the laptop, press the power, if it starts up the battery is bad and needs to be replaced.
Jan 13, 2011 | Gateway M-6750 Notebook
My gaetway m6750 will not turn on
The issue probably may be power supply related. You can try removing the Battery and connect the Computer to direct power outlet. Reseat the RAM modules before sending to service depot
Jul 01, 2010 | Gateway M-6750 PC Notebook
No power to my gateway m-6750 lap top. Have been
First use the following steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
If everything remain same, check the charger with a multimeter and match the voltage output with its specs.
If the charger is good, then there can be some problem with the DC jack (where you connect the charger).
Feb 25, 2010 | Gateway M-6750 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
My M6750 notebook monitor will not light up(it's
The fault could be a faulty inverter or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp anf the CCFL lamp is a tint fluro lamp and it dims with age or fails like any fluro lamp.
You could test the voltage output of the inverter with a multi-meter or just replace it cost about $40 and the CCFL lamp cost about $10.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
Sep 28, 2009 | Gateway M-6750 Notebook
Gateway M-6750 Motherboard Power Short
these little moving pieces tend to fry the motherboard.any rattling noise is a concern...
Jun 16, 2009 | Gateway M-6750 Notebook
Powering On Issues
With the power not staying on, its a motherboard problem. Try another ac adapter just to be sure just to rule out a faulty ac adaptor.
Mar 31, 2009 | Gateway M-6750 Notebook
M6750 lcd whiteout
its going to need to be troubleshot deeper. Its either going to be an lcd, inverter or a motherboard problem. The only thing to do is to try another lcd and inverter. If those fail, then it has to be the lcd connector on the motherboard which means the motherboard would have to be replaced.
Jan 19, 2009 | Gateway M-6750 Notebook
Computers & Internet Logo
1,466 people viewed this question
David Payne
David Payne
