Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi tv won't turn on
I have a hitachi 50ox19k been great tv but now what started as an intermittent problem is now perm.when i power on the set it makes a click sound as if it were going to power on but immediately turns off.i read about a 2 amp pico fuse and a c707 capacitor as poss culprit but cannot locate on board,also read that ic's could be culprit can someone help me plz.
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: Hitachi 50H72 Convergance issue
they look like tiny resisters,you check them with an ohm meter and they should show little resistance, have you checked the resisters in the convergence area there should be about 6 of them 1.6 ohm to 3.9 ohms.
Posted on Feb 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: Hitachi 53UDX10B Power Light Flashing after convergence IC replacement
C603 is a polyestor capacitor 0.068UF-FEB 50V part number 0880047R S901 is the power relay ALKS329 the part number for the relay is FJ00142 . I recomend checking the pins on the ICs to make sure they are not bridged. If you need more assistance let me know. Vance Baldwin should have the parts if not you may have to order through hitachi
Posted on Jun 06, 2008
kevin000
  • 1847 Answers
SOURCE: Mitsubishi Rear Projection WS
it's a convergence problem, as mentioned go into Settings in the TV menu and select Convergence if Auto it will do it when you select this. If not it will ask you to do "Multi-Point Convergence" which will bring up a huge grid on your screen. You must use the TV remote and using your up and down and left and right buttons to place the "curser" on each grid and adjust the Red and Blue on each point till you get a pure white "grid point" Think of the picture as split up into say 72 different puzzle pieces and when you adjust each piece it fixes that one piece of the puzzle or screen. You want all lines to be pure white and by looking at the grid if you see either blue or red on the side of the white line, you want to move the right, left, up or down button so that the blue or red line gets back on track with it's corresponding white line grid.
It sounds complicated but you will get it after a few seconds of playing around with it. Convergence should be done after the TV has been on for at least 30 minutes and should be done at least once a year (twice would be better at minimum) You see the problem with RPTV is they use three color lenses and as you watch TV, the lenses over time get out of alignemnt and need to be readjusted to get a clear sharp picture.
I adjusted a TV once that had never been converged in ten years and it took me over two hours to get all 72 points back on track, once done you will notice a way sharper picture and the colors won't be off kilter.
It takes time, but once you get it, you'll get it. I converge mine once a month and it takes me about 2-3 minutes to do the whole screen because I keep up to date on my 58" Pioneer RPTV.
Posted on Sep 21, 2008
  • 38 Answers
SOURCE: HITACHI 50UX10B AP23 CHASSIS NO POWER
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
Posted on Oct 13, 2008
Shuttle83
  • 1139 Answers
SOURCE: Hitachi 43fdx20b Need capacitor but i dont know which to buy!!
Hello Soleftright,
I have CK24 as a 1000pf 50v cap. Look at CK25 it is the same value as CK20 - CK24. Were your convergence ICs STK392-110s? One side of the cap goes to pin 14 of the (IK-04) IC and the other to ground.
I hope this helps
Thank you,
Shuttle83
Posted on Nov 20, 2008
Hitachi 60sx12b. when you turn on, clicking sound, don't turn on.
Replace micro fuse F903 (5amp). It's located near the biggest 2 caps. in power supply area.
Jul 20, 2009 | Televison & Video
TV will not turn on.
repaired two sets, both had a blown fuse (E???) and shorted capacitor (C707). These parts cost me $2.00.
Search for the keywords Hitachi and C707.
-dan
Jul 04, 2009 | Hitachi 50UX57B 50" Rear Projection...
Wont power on
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jun 21, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Hitachi
What you are hearing is the impending death of some component.
I see your post is old so I won't spend too much time on it.
Certain capacitors and semiconductors will produce this kind of noise when dying.
An intermittant solder junction can also do this.
It would take some signal tracing skills to locate the origin though I suspect you have already paid for the work or given up on the set.
Nov 04, 2007 | Hitachi 43FDX01B TV
Hitachi 31cx6b
Sounds like a power supply issue.
Jun 05, 2007 | Hitachi 31CX6B * 31" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
