Question about Kenmore 46462 Front Load Washer
F01 Error code
During a thunderstorm, the power went out during a wash cycle. When the power came back on, the washer was flashing an F01 error code. I followed the instructions in the manual, but the cycle gets to about 6-7 minutes left and stops, flashing the same error code. I've tried unplugging the machine, but it didn't work. What can I do to fix this?
  • 3 more comments
  • Anonymous Apr 12, 2008
    New washer model 47532 kenmore HE2plus front loader. Came home had storms. Apparently power out. F01 Error code. Instructions in book do not work. Need help now!!
  • mssmdny Apr 20, 2008
    Electrician added outlet to laundry room, afterwards, clothes not draining and wet at end of cycle- nothing blocking pump filter. F01 error. How to Fix??. Sears next appt for repair is 2 weeks!!. Help
  • sfb83301 May 12, 2008
    i had to cancel during the wash cylce and when I went to do restart, it gave the f01 error. I unplugged for about 25 minutes, but it did not work.
  • vehern Apr 27, 2009
    Our power went out due a thunderstorm. We also received the F01 code when the power returned. What can we do to remove this error code and continue our cycle?
  • Anonymous Mar 14, 2014
    Washer went thru all the wash cycles and when it stopped door would not open and power will not come back on.
    Genius:
  • 1,028 Answers
Most likely suspect main control bd
Posted on Apr 19, 2008
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
My machine is displaying code F01. It comes up at the end of the wash cycle. However, It doesn't seems to be actually washing the clothes anymore. The water runs in and out of it , but I don't...
I tired answering yuor post and there is a problem with the website. I have reported same to the website staff. You should see my post via email soon
Kelly
Sep 24, 2011 | Washing Machines
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
It hasnt been getting the clothes dry during spin cycle, this time it is flashing F 01. Sometimes I can reset it but this time the tub will not spin on any cycle
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite 45986 Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Getting error code F1 and don't know what it
Apr 19, 2010 | Kenmore HE2 Plus Front Load Washer
F1 light comes on during spin what should i do?
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 46462 Front Load Washer Logo
680 people viewed this question
Sal De
fordexpert
Robert Rankin
