Question about Tascam Pocketstudio 5 MP3 Player
Pocketstudio 5 Whats a cf card, and how do I make one?
A CF card is a compact flash memory card. It's rectangular and has two rows of holes along one side which fit over the connector pins when you slide the card into its socket. Compact flash cards can be bought from electronics or photographic shops, and some department stores. They are not expensive but these days they are usually 1Gb and up. The TASCAM Pocketstudio 5 can only format up to 128Mb so most of a modern card is not used but the card will still work.
Posted on Jan 02, 2009
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
I own a Canon Powershot pro 90 IS with 16 MB CF memory card. I want to upgrade the card. Can you tell me whats the maximum capacity the Camera can take.
The camera can take whichever capacity card your want. Type 1 and 2 CF cards up to and past 16GB are available. It is really what you can afford and how many frames you want to put on a single card before downloading it.
Aug 30, 2010 | Cameras
PocketStudio 5 Error - encDSP Init Err
I turned off the unit, then while holding down rew and record buttons at same time, turned on unit. I don't know why, but it worked.
Feb 07, 2009 | Tascam Pocketstudio 5 MP3 Player
Err Pttrn File issue
Vista shouldn't prevent you from transfering data to a TASCAM Portastudio. The instruction manual shows how to connect the Portastudio to a computer using a cable. The instruction manual can be found on the internet and is called ps5_ref.pdf
If you have a CF card reader you can put the card in that and it will show up in vista as removeable disk. You then use Explorer (windows file Explorer, not the browser Explorer - who knows what fool at Microsoft gave the same name to two different programs) as normal to move the files FXPATCH.PKT, PATTERN.001, and SYSINFO.PKT onto the CF card. You use the same method to transfer your recordings and MP3 files from the Portastudio to the computer if you want to. Just remember to stick to the 8.3 naming convention - that's up to eight letters, a full stop, and three letter extension such as .MP3
Aug 28, 2008 | Tascam Pocketstudio 5 MP3 Player
Tascam pocketstudio5
Hello tasbones and razzledog !I expect the following will help you solving the problems with the pattern file of pocketstudio5 (TASCAM):You need the original CD-ROM which includes the pattern file with many different drums and sound stuff. You have to put these data on a formatted cf-card (everytime again if you will use a new card) !This info comes from a german musician who had the same problem 5 years ago.Try the following Link of TASCAM where you can download the manual, an update and the PATTERN FILE !www.tascam.de   --> "Support" --> "download" --> "nicht mehr hergestellte Produkte" --> "pocketstudio5"If this will not work, give me a sign - I will try to send the data to you via mail.freewood/Berlin, Germany
Dec 24, 2007 | Tascam Pocketstudio 5 MP3 Player
Extreme Difficulties With My Canon
Problem #1
this is not a problem.. if you leave the camera in the ON setting for long enough.. it goes to sleep ... in order to conserve battery life.. you need to keep some of the buttons pressed for a bit for it to wake up... e.g. keep the picture taking button depressed for 5 secs.
Problem #2
If you were checking the pictures after just shooting them then its probably a CF card problem. You can also get the same error .. i.e. corrupted files from the cameras perspective.. if you use a CF card reader and try to change the pictures on the card.
You should try to connect the CF card that has those pictures to a computer it might be able to open them.. .
Otherwise try another CF card.
Nov 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Not recognized by computer
http://www.tascam.com/Products/PocketStudio5.html There is a menu on the left with all the documentation, as well as downloads of their software updates. This product is discontinued, so no further support will be available from the manufacturer.
Dec 09, 2006 | Tascam Pocketstudio 5 MP3 Player
Compact flash cards
what is the solution for this problem posted by tiller on Sep 26 2006
Sep 26, 2006 | Tascam Pocketstudio 5 MP3 Player
Tascam Pocketstudio 5 MP3 Player Logo
160 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
