Question about Hoover Vacuums
HOW DO YOU REMOVE THE BASEPLATE ON THE HOOVER ZOOM
I LOGGED IN TO THE HOOVER SIGHT AND FOUND THE INFORMATION THERE
Posted on Apr 12, 2008
Its the widepath bagged tempo, i need to change the belt but do not know how. How do i change the belt
remove 4 screws fromthe bottom of the vac. this will allow you to remobe the baseplate and expose the belt & roller. put the new belt on the roller first and then pull it to the motor shaft. Note: remove the roller and the housing under it to clean out any debris buildup. re-install baseplate and screws.
Oct 28, 2009 | Hoover Tempo Widepath Upright Vacuum -...
How do I change the belt on my Kirby sweeper?
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate and you can access the belt.
You can get a replacement belt here:
Kirby Ultimate G Replacement Belt
Oct 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Base Plate screw rotating in insert and not coming out. Insert come unfixed with screw still attached. Therefore unable to remove baseplate, unable to remove cotton fibres from brushes. Have you an...
Try to remove all other base plate screws first. If they can be removed gently try to pull open by hand against the lid while rotating the remaining screw. You will need to apply outward pressure betweent the insert and baseplate to remove it while rotating with a driver and using the separating pressure to allow it to unscrew.
The inner housing may have a cap nut on it which has spun loose or the threaded area of the housing has likely cracked if the head has been dropped.
Sep 08, 2009 | Vacuums
Installing roller brush for oreck XL 21
uh, probably not sure what the issue is, but
1. unplug unit.
2. Remove the multiple screws from the bottom of the unit.
3. remove the bottom baseplate (usually black)
4. the brush roll is now visible, and the belt should be around it.
5. Pull the brush roll away from the unit, and disengage the belt.
6. Replace in the opposite order. Make sure that baseplate fits properly to insure a good seal. Also watch the bumper (rubber part that is wrapped around the unit) to make sure it is properly seated.
7. Handroll the roller brush before plugging in. Make sure it moves freely.
8. Run unit, may get a slight burning smell, but if this continues for more than a minute - turn off and inspect the unit. Brush roll requires a short burn in time, on initial build, factory accomplishes this during test procedures.
Jun 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
No suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
-R
Feb 25, 2009 | Riccar 8850 Vacuum
Vacuum is not self-propelling and no suction
Replace your rubber belt, it is what powers the self-propel mechanism.
Remove the 4 screws from the baseplate and replace the belt at the rear of the machine.
-R
Sep 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Oreck xl upright vacuum
Remove the five screws from the baseplate and replace your belt by removing your brushroll, putting the belt over the motor pulley, and then over the pulley on the brushroll, then replacing the brushroll in its original position and screwing the baseplate on. Note that you should make sure that the bearing ends of your brushroll spin freely prior to doing this to avoid the belt breaking again.
-R
Sep 18, 2008 | Oreck Vacuums
No suction
Flip the machine upside down and remove the four screws from the baseplate. Replacement should be fairly self-explanatory from there. If it's a self-propel model, note that the v-belt in the front WILL look loose normally, so it does not usually require replacement.
If you have a self propelled model, the belt you need ends in 035, if it's non self propelled it ends in 033.
Contact me if you need more assistance in changing the belt.
-R
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a windtunnel bagless twin chamber. Model U5753-960. carpet adjustment is not working. It's harder to push than it was. It is not sucking up everything it should be. I just put a new filter in. ...
You probably need to replace your belt. Rubber vacuum belts require replacement every 3-6 months.
There are 4 screws on the bottom of your machine on the plate covering the brushroll. Remove these, remove the brushroll and belt, place the new belt over the motor pulley, (the metal bar sticking out of the motor,) then place it on the brushroll and pull the brushroll back into place. Spin the brushroll to ensure that the belt is not pinched, and replace the baseplate. Party.
-R
Aug 11, 2008 | Hoover Vacuums
Agitator bar makes a rattling sound when engaged.
Unfortunately, you may need a new brush roll.
Read this review and see what you think.
click here
May 04, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Vacuums Logo
22 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
