Question about NAD C320 2-Channel Amplifier
Amp wont switch off of stand-by
My NAD 320B Amp powers up with red standby light which never goes green. Anyone had this before?
  • deonlot May 08, 2008
    Hi - exactly the same. Opened up and found 1 of the large capacitors had loose joints but after resoldering, problem still there. After about 1 - 2 hrs it does come on but then only works on a low level. Clips and distorts. Beautiful amp ....when it used to work.
  • gummi321 Dec 12, 2008
    i have the same problem what outputs are we talking? can i fix this myself ? know lil about electronics . just if you could tell me what i am looking for thanks GS
  • 4,234 Answers
Both units have a problem with the output section. In case 1, the outputs are likely to be shorted. In case 2, the outputs are open. The low level and distortion come from you driving the speakers with the driver section of the amp. Both units will need to see a service provider.
Dan
Posted on May 19, 2008
My p315 speaker stays on standby and won't power up?
some design need audio signal in to get it wake up from standby mode.
Oct 25, 2012 | Acoustic Research P315 HO Speaker
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Televison & Video
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
C320 only red light goes on, doesn't switch to green and speakers start humming. None of functions work.
HI...
There are failed components in the power supply -to-power amp section.
I can suggest a repair place if I know your area
Thanks
May 01, 2009 | NAD C320 2-Channel Amplifier
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Won't stay on even in standby
The voltages are wrong. You should see (0.0, +/-0.6, and B+/B-) on the 3 pins. The driver section has a problem. Check the driver stage for shorted transistors or open resistors.
Dan
Mar 19, 2008 | NAD C320 2-Channel Amplifier
NAD C320 2-Channel Amplifier Logo
398 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
