Question about Lands Phones
Have a fairly battery but while in use the phone begins to beep and then goes off completely. Bought in January 2001.Shouldn't the phone last longer? Planned obsolescence??
Guess I'll just chuck and buy a new phone.
EUF
Posted on Apr 12, 2008
Charge complete
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm thanks........
May 02, 2013 | Cell Phones
How long do batteries last in a Three Handset VTECH 5.8 Digital Phone System?
batteries last up to 3 years and from e-bay are a fraction of that price
as for time in use should be at least 1 hour for a good battery
it is vital that after use you return the phone to the charge cradle
ensure that charger is operational
Apr 03, 2017 | Vtech Cars & Trucks
The machine's flow drips at the beginning and then stops completely without making any coffee, tried everything including detailed cleaning. It sounds like the pressure is not strong enough to make...
Yes you should have a warranty on it and it should be covered. It shouldn't matter if you haven't registered as you still have your proof of purchase and the machine does not work as intended.
Aug 29, 2011 | Breville Fresca BES860 2Cup Coffee Maker
I haven't used this camcorder in a couple of months (bought new in January). When I went to charge it last night, neither the mains charger or USB lead will charge it. Does it just need a new...
The battery should be good if it was bought in January, with that said nothing is nperfect or lasts forever, there are always issues with some things. If all your connections from the charger or USB are good and tight and the cables are good, the either the battery is bad or the plug in on the camera is bad, or the battery nmay be installed incorrectly. That is about all there can be .
Jun 03, 2011 | Cameras
I got this camera last June and it's been dead since January. Every time i try to charge it, it will not respond to the charge.The battery is completely dead, but when the charger is plugged into...
Hi, Sounds like the battery is toast. Batteries can stop charging any point in their life span. Usually I'd suggest just buying a new battery but because a battery shouldn't die like that within the first year I'd suggest contacting Nikon in your country and seeing what they'll do for you.
May 18, 2011 | Nikon Coolpix S4000 Digital Camera
Battery
A noticeable malfunction of cordless phone due to batteries discussable
1. The cordless phone allows to acquire calls away from the receiver area
2. The cordles phone requires frequent battery charging becaus not designed for extensive sessions away from recharge docking station.
3. The further away the phone is from docking requires more battery
Problems with batteries discussable
1. a malfunctioning battery continuous to beep
2. A malfunctioning phone batteries requries replacement completely, cannot be recharged any more, remove, discard and acquire a new battery to replace soon as malfunctioning beeps are heard lasting several attempst to recherge without seizing beep.
Dec 02, 2010 | Siemens Gigaset A140 Cordless Phone
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell phone won't charge/or hold a charge
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm :)
Jun 23, 2008 | Cell Phones
Wont turn on
Are you sure that your batteries were fully charged? I have the same issue when using shop bought aa batteries - or they don't last very long at all.
That 3 beeps and turning off is what should happen along with a "battery low" error message on the screen from experience.
When I bought the recommended charger and two batteries from Amazon - they lasted a lot longer. Search the website for the charger battery code suggested in the instructions.
Dec 16, 2007 | Samsung Digimax S730 Digital Camera
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
