Question about Intertherm P3RA-042K Air Conditioner
Compressor I have a air condition unit that blows out cold air for a little while and then the air in neither cold nor hot. I had someone come and check it out and they said the compressor was bad. Is that really the problem or could it be something else? The model I have is Intertherm T3RC-042K. I just don't want to have to spend that much money on fixing the compressor and that is not the problem. If it is the problem, is it something that can be done yourself or does a professional need to do it?
  • Mrsjtds Apr 13, 2008
    So does that mean I need to buy a new compressor or do I need to buy a whole new unit?
    Genius:
  • 1,073 Answers
If the unit does blow out cold air for a few minuets then quits it could be a low pressure cut out that will turn off the compressor because the unit is low charged mening there is a leak in the sealed system i would get a second opinion and show them this post
Posted on Apr 12, 2008
A/c blowing hot air with low pressure
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
Jul 09, 2013 | Cars & Trucks
Air conditioning blows hot and cold air
You will need to know if the compressor is working when it blows hot air to proceed. It could be an electrical problem, a blend door problem, or the a/c clutch on the compressor.
Jul 02, 2012 | 1999 Honda Civic
1992 Dodge Dakota 2wd 3.9L V6 Air conditioning/Heater dosent blow? when i turn the air or the heat on i can hear the compressor kick on but it dosen't blow cold or hot? any help would be appreciated
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
Nov 29, 2011 | 1992 Dodge Dakota
My 1990 testarossa air conditioning is not blowing out cold
Hi! ss519
Do you have guages or electrical meter. Will the compressor run, if the unit is low on freon, the low pressure switch will not let the power feed the compressor clutch. Just need a little more info.
InMrFixIt
Jun 19, 2011 | Air Conditioning and Heat for Ferrari...
95 Chevy Surburban. Air conditioning issue, front air blows warm, rear unit blows cold. Have replaced orface 3 times, replaced compressor 3 times, replaced accumulator 2 times, flushed condensor,...
they run off of the same compressor if rear is cold and front is hot the hot and cold function in the heater box is not working possible cable problem ? or a vacum line under dash
Aug 04, 2010 | 1995 Chevrolet Suburban
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
Central air conditioning blowing out hot, not
Can you tell if your outside unit is running (the fan and compressor)? Sometimes it is hard to hear the compressor for the fan. If they are running then you possibly have a low refrigerant charge and need to have some added. Refrigerant pressures and temps can be checked to verify this. If they are not running then you need to find out why. If both the fan and compressor are not running then first make sure all the breakers and disconnects are closed. Then a bad contactor or capacitor could be the problem. If its just the compressor that's not running then it could still be the capacitor or maybe the compressor.
Apr 29, 2010 | Heating & Cooling
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Intertherm P3RA-042K Air Conditioner Logo
195 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
