Question about Samsung SGH-U600
Connecting bluetooth too samsung phone
How >?
  • 34 Answers
Make sure u have made a bluetooth name up for it to connect to look at ur setting on bluetooth see if there right
Posted on May 22, 2008
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
Dec 29, 2014 | Samsung Radio Communications
I want to connect with my samsung gt-s5233A
if you want connect bluetooth then switch on both bluetooths and search for new devices on your phones see the bluetooth name and connect....
Oct 22, 2011 | Samsung Star GT-S5233 Cell Phone
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
I can't connect my Samsung Jet with my PC via Bluetooth. What am I doing wrong?
to connect your samsung phone to a pc via bluetooth you need to follow the steps.
1. install your samsung pc suite NPS,
2. open your phone bluetooth.
>> go to menu, select bluetooth, select settings under bluetooth, make your phone bluetooth's visible,
3. go to your computer, open your bluetooth, right click the bluetooth icon on the system tray, they are grouped and can be located near the clock.
4. select settings for your computer's bluetooth, make it discoverable, check the discover services.
5. under the computer's bluetooth panel, you can see there add device, click add device.
6. once the computer search for your phone, pair them with passcode like 1234, or 0-9 digits, it's up to you to assign the passcode but make sure they will be having the same passcode. ( both computer and phone).
once paired you can see them there in your phone's bluetooth panel, your computer and your phone together.
>>to check if successful connection was achieved, select a file from your computer, right click and send to your phone.
>>do the same thing for your computer, select a file from the phone and send it to your computer, but you need to confirm that your computer will be receiving a file from a paired bluetooth, by clicking the balloon
message at downright corner of your computer where your bluetooth is located.
regards...
Mar 02, 2010 | Samsung Jet S8000 Cell Phone
I can not play music in bluetooth headset in samsung sgh j600 in my phone..!! Pls help..!!
hi ajit is here if ur bluetooth is not connect 1st on the bluetooth device n phone bluetooth press the bluetooth suplly key when u not se continous lite after thie search bluetooth n connect password is may be 0000 otherwise some hardware problem because of fall on the surface
Jan 21, 2010 | Samsung SGH-J600 Cellular Phone
Bluetooth not connecting
try pairing with other devices. sometimes pairing is essential for connection
Jul 20, 2009 | Samsung SGH-X820 Phone
How to connect samsung e251 to pc as a internet modem bluetooth
u need to purchase bluetooth doggle nd install software of bluetooth in pc then connect it ur work is done...
Jun 03, 2009 | Samsung SGH-E251 Mobile Phone - Black
Problem with bluetooth
My mobile Bluetooth does not connect and it will right me that bluetooth failed
Jul 14, 2008 | Samsung X820 Cellular Phone
Samsung SGH-U600 Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
