Question about Xerox Phaser 8500/DN Printer
Xerox 8500 Error 07,101.43:20955
My Xerox 8500 printer has an error 07,101.43:20955
Printer was working fine and the next morning tried to print to it and during thee warm up process the above error occured. The printer warms up to around 10% everytime and the above error occurs.
Please help.
Thanks
  • Roshgo Apr 11, 2008
    Yes you are correct sorry about the the typo it is:
    07,010.43:20955
  • Roshgo Apr 14, 2008
    Thank You. I got it repaired it was the ink
    President:
  • 2,072 Answers
That has to do with the process drive gear box. May be mis timed or a gear broken.
Posted on Apr 11, 2008
  • 1 more comment
  • Rick Kasper Apr 11, 2008
    You are sure it isnt 07,010,43 ????
    Ok then thats much better .
    That code has to do with the print head tilt.
    There are 3 things that usually cause that.
    Most of the time it is the print head block, which if you remove the left side cover, (looking from the front) it is a stainless steel block located about mid way back on the machine, toward the bottom. It is about 1 inch square, and ink leaks into it and makes it very sticky, The print head then can not pivot betwen the home and print position.
    The second most likely problem is the wiper blade is stuck to the print head. You can try turning it off and on a few more times, but if the wiper is tacked tightly, you will have to remove both side covers, and the ink loader, and gently pry the blade off the print head.
    Thirdly are the cables that attach to the print head are restricting the free movement of the print head.
    None of these are real difficult to do, Just take time and patience.
    If you want more procedures etc. let me know. This is normally a pretty easy fix.
  • Rick Kasper Apr 14, 2008
    Great,
    Glad to have been able to help.
    Not to terribly bad a job.
    I forgot, in case that happens again, that block is pretty easy to remove once that spring holder is moved into position.
    But I was neglent in mentioning that the block cleans easier if you have the time to soak it in some very hot water. It softens the ink and makes the block easier to clean.
    Good job.
Phaser 8500 error code 19,003.48:64663
19.003:48 is the error code 64663is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
Dec 12, 2013 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 19003.48:33702
19.003:48 is the error code 33702 is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
May 21, 2012 | Xerox Phaser 8500/DN Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Printer not working, error code 07,009.42:12244
Printer Errors 07,007.49 – 07,008.41 – 07,009.42 – 07,010.43 indicates that the printhead was unable to tilt normally on its axis.
run into and even though the diagnostics check out ok when I removed the ink loader I could see the print head was stuck towards the front. I slowly moved it back and after that the printer worked fine.
Nov 03, 2009 | Xerox Phaser 8500/DN Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Error code 19,003.48:75856
That is a print head calabration fault. 99 percent chance the print head has failed. That would require replacing hte print head.
That is a common problem on the 8500. Look for a dealer in your area if you want to repair is. Xerox will charge over $200 to show up and $750 for the print head.
Jan 29, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Collate issue
Have you tried switching the type of driver. From PS to PCL ?
I will look up more in the morning and get back with you.
Jan 29, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
313 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
