Question about JVC KD-G230 CD Player
My 6 disk CD player is in the eject mode(front open no disk in 1 slot but won't load)
Please help if you can. My 6 disk Cd player in my FORD Expedition is stuck. I have no disk in the 1 cd slot.(it was ejected) All others have cd's. The little door that opens to slide the cd in is open. Everytime I try to load,then press 1 it says CD Error. I try to put a CD in? It won't grab and slide in, the Cd just stays there like a bump on a log. If I push it in? It gets stuck and I have to get two Cd's, smash them together to grab it and fish it back out of the slot. The light on the 1 on the display is dark. All the others have the lights lit (2-5)
What can I do to get my player working again! I'm going CRAZY not being able to get it to work and I don't want to have to spend a buttload to fix.
Thank you SO SO much.
I had the same problem with my 6 disc in my ford focus that radio should of had a recall my advice is to just get a new cd player cuz first its the cd that goes then its the radio
Posted on Mar 09, 2009
Yank it and get an aftermarket double din player
Posted on Oct 21, 2008
  • 86 Answers
Get a boyfriend - they know how to fix this stuff. Especially an Hispanic. It may be that there is a disk already in it. If not, the motor on the CD player is bust or the laster is trashed. Either way, it needs repair if there is someting stuck in it. Cellphones with MP3 and in ear headphones have good sound to get you thru work traffic and home again
Posted on Apr 11, 2008
6 disc CD player won't play, eject a loaded CD or load a new CD
You may have to remove the radio and disassemble it remove the jammed CD. Unfortunately, there is no easier solution for the problem.
Aug 31, 2016 | Car Audio & Video
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
A CD is stuck in my bose system How do I get it out?
From an other web site
PART I
PART II
Oct 09, 2014 | Bose & Wave& Music System
Qx56 2004= trying to load a disc but when inserting about 1" of disc in, system said push eject. I pushed eject but then system switched to FM mode. Now I cant switch to CD mode when push CD button....
Sounds like that the cd is jammed inside the players so you could either take the player out the dash and open it up yourself or take it to a dealership/repair shop for them to fix it for you.
Also there might be a small holes located under the cd slot big enough for a pin to release the cd manually?
Jul 29, 2011 | 2004 Infiniti QX56
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
My cd player won't eject cds
you might try and look inside the CD slot with a flashlight and if you can see a CD try to remove it with tweezers,you do have power to the player right? if no power it wont eject,
Jan 11, 2009 | 2002 Ford Excursion
Dvd wont eject
hi jodestar,
i am having the same problem with my player. how did you end up fixing yours?
Sep 23, 2007 | Philips DVDR3455H/37B
JVC KD-G230 CD Player Logo
449 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
