Question about Dishwashers
Waste water pump running all the time and no water is coming in
  • 86 Answers
Is the tap on? The exchange of pressure is dynamic and relies on this exchange
Posted on Apr 11, 2008
On a water cooled scotsman ice machine, should the water be running out of drain line contiuously as its making ice? be cause it just runs all the damn time and thats a huge water bill ...
On a water-cooled system, by design the heat from the machine is being transferred to running water that carries the heat away. Some installations pump this "waste" water to a heat-exchanger or cooling tower (typically on a rooftop), where the heat is transferred again, this time to the air. The water with the heat removed is then recycled back to the machine, where the process is repeated continuously. There is thus no "wasted" water.
If your cooling water is just running down the drain, that's a terrible waste of water and money. Try to find a way of recycling the water by removing the heat and re-using it. Think of ways to use the "free" heat in the water.
Alternatively, buy a proper rooftop heat exchanger and pump the water through it, or, get an old car radiator or air conditioning condenser and a decent blower, and make your own.
Remember that your machine needs constant cool water in order to avoid overheating the system.
Oct 31, 2013 | Kitchen Appliances - Others
Hayward vari flo valve on filter also comeing out waste at same time
Yes, it is the "spider" gasket inside the valve that has gone bad. It needs to be changed out. They are not expensive. Go to YouTube and enter "change spider gasket" there are several videos. Good luck with it!
May 11, 2013 | Pool & Spa
Water is running out the waste valve when the pump is running and filter is set on filter. How can I get this to stop?
You may need to disassemble the top of the multivalve, make sure the handle is 180* to the "Cam"
Jun 14, 2012 | Hayward SAND FILTER, PRO SERIES
Machine just started leaving dirty water in bottom of machine. cleaned filters,had machine apart,removed and cleaned waste pipe. pump runs and impeller feels ok.only time i could get any water to drain...
Check that the pump is clean and not loose. Make sure pump, impeller, and waste pipe are in alignment with each other and are clean. If it works when you shake the pipe, then there is still a clog inside or the pipes aren't aligned correctly and something is hanging up.
Dec 31, 2010 | Dishwashers
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
No water is coming out of the jet. What should I
With the waste collected in the filter, it means that there
was water moving at the suction side. It is either the discharge valve is close, defective valve, or clogged jets.
So, please check the three possibilities. and get it corrected. Send us your e-mail for further assistance.
Sep 02, 2009 | Plumbing
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Gasket on hayward 712-2 is slightly warped water comes out of backwash at same time filter is running. need new gasket. temp fix of raising the seat of broken spoke not working. filter runs fine if valve...
Buy a new gasket and install with some sort of gasket lube.
Selector (rotary) valve operation: Do not move selector valve unless pump is off, and always move in a clockwise direction.
'Waste' selection bypasses filter completely and sends water directly out of pool backwash port
May 18, 2009 | Pool & Spa
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
