Question about Casio Exilim EX-Z750 Digital Camera
Pictures default to internal memory not the SD card
I've had the camera serveral years and have had great service.
Recently my pictures do not copy to the SD card but go directly to the internal memory until it is full and I'm blocked from taking any more pictures.
I used to be able to pull the SD card and either download to my computer or print directly from the card.
I've read the manual cover to cover and found no mention of this problem or information that there even was an internal memory.
  • Road Thunder Apr 12, 2008
    I performed the task listed and it didn't help, bummer.
    mccomijohns, thanks for trying.
    I'm not sure the camera is worth fixing. I'm very much interested
    in the Panasonic camera with the Lieca lens that is similar in size to the Casio.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
  • 477 Answers
Go into the menu of the camera and goto the setup option and goto reset and reset the camera with the card in. then go back into the menu and try formatting the card it is located right next to the reset feature hope this helps if it does not work then the memory card reader in the camera is damaged and the mainboard needs replacement. I repair these camera all the time. hope this helps.
Posted on Apr 11, 2008
How do I take the pictures out of the internal memory and put them on an SD card so I can take them OUT of the internal camera memory?
Use the "Copy" command in the Playback menu to copy the pictures from the internal memory to the card. Once the pictures have been safely transferred to your computer, format the internal memory to clear it.
Jun 19, 2012 | Nikon Coolpix S6100 Digital Camera
I have had my camera for 3 years but never had bought a memory card for it. I recently purchased one from Walmart. When i put the memory card in the digital display almost gets stuck and won't open so...
The camera takes SD cards up to 2GB (not SDHC cards). If you've been taking pictures using the camera's internal memory, you must first get rid of those pics. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert your new card and go through the "format" routine again to prepare the new card.
Sep 02, 2011 | Konaki DV7-Z Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
Hi, I took some great pictures recently before i realised my kids had removed the SD card, the camera came with a cradle to charge the battery and to download the pictures, this cradle is now broken, is it...
You can't copy individual files, but you can copy all files from internal memory to an SD card.
  1. Load the card to which you want to copy.
  2. Turn on the camera, enter the Play mode, and press MENU.
  3. Select "Copy" and press right-arrow.
  4. Use up/down-arrows to select "Built in -> Card" and press SET.
For full details, refer to page 203 of the manual.
Aug 31, 2010 | Casio Exilim EX-Z1200 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Can photos be transferred from internal memory to sd card
    im not sure on yours but on mine there is a option for copying a picture under the menu just go to the pic you want on the externa. memory and go to your menu find copy picture and then it will copy to it
    May 01, 2009 | Kodak EasyShare C663 Digital Camera
    Casio Exilim EX-Z750 Digital Camera Logo
    87 people viewed this question
    Top Casio Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Casio Camera Expert? Answer questions, earn points and help others
