The ink cartridge wont stop moving - Office Equipment & Supplies
  • peter doran Apr 15, 2009
    When try to replace an ink cartridge(s) the compartment into which they slot and which runs on a metal rod at the back of the printer does not stop moving, making it extremely difficult/harardous to impossible to replace an empty ink cartridge.
    I've found that shielding the opening with both hands (one each side of opening) and have someone else remove and replace the affected ink cartridge (in d.quick time) meets with some success.
  • 86 Answers
Pull the power cable
Posted on Apr 11, 2008
I had same problem getting cartridge back in carrier. I called
epson.com tech support an she told me to push green
button on right-then just wait while it races back and forth
until it finally stops in right place and stays set while you
replace cartridges then push green light again.
Works perfectly.
Posted on May 14, 2009
I have forgotten how to move the ink cartridges into a position where they can be changed.
Turn on the printer. Open the top of the printer to expose the ink cartridge compartment. Hit the "Stop" button. This will cause the printer head to move so that one of the two ink cartridges move above the "No Ink" icon. Hit the "Stop" button again. It will move the other ink cartridge above the "No Ink" icon if it needs to be replaced. The printer head will move to the original position to the right.
Aug 29, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I cannot stop the ink cartridge holder to stop in the correct positioo to replace the cartridges on my epsom cx5500 printer
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light (fon3_66.gif) is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing fon3_66.gif means LOW ON INK, and a steady fon3_66.gifmeans OUT OF INK.
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
Aug 22, 2011 | Office Equipment & Supplies
I just replaced all my inks and it is still telling me to replace my cartridges i also turned it on then off
  1. Open the scanner.
  2. Press the cp_button_14.gif Stop button to move the cartridges to the replacement position.
    Caution: Do not move the print head by hand; this may damage your all-in-one. Always press and release the cp_button_14.gif Stop button to move it
  3. Open the cartridge cover.
  4. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  5. Close the cartridge cover and push it down until it clicks into place.
  6. Close the scanner.
  7. Press the cp_button_14.gif Stop button to begin charging the ink. This takes about 2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Never turn off the Epson Stylus CX while ink is charging or you'll waste ink.
    If the ink light flashes, press the cp_button_14.gif Stop button and press down all the cartridges securely.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 22, 2011 | Epson Stylus cx7450 All-In-One InkJet...
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to I change ink on epson printer NX127 I cannot get the cartage out Can you show me the picture of the cartage ink holder with the lid up
First make sure the printer is on, then open the printer cover and the cartridge cover. Then press the Stop button. Assuming the printer has identified a cartridge with low ink, that cartridge will be moved to the replacement position; then the power light will flash. Squeeze the tabs on the ends of the cartridge together and lift it up. Unpack the new cartridge and remove the tape carefully. Then press the new cartridge into place until it clicks.
If more than one cartridge has low ink, the leftmost one will be in the replacement position when the cartridge carrier stops moving. Press Stop again to advance the carrier to put the next low cartridge into the replacement position. Then press Stop again to have the printer move the cartridges to the home position and charge the print head. When the lights go out or stop flashing, close the cartridge cover and the printer cover.
If the cartridges aren't low on ink, then use the Epson printer utility (under the Maintenance tab) to start the process.
For pictures of the Epson printer during ink replacement see: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1558177770.1297529968@@@@&BV_EngineID=ccdcademkhmjkgicfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=150187&prodoid=63088089&foid=157388 . Alternataively, see http://files.support.epson.com/htmldocs/nx125_/nx125_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=Ink.7.1.html .
I hope this helps.
Feb 12, 2011 | Epson Office Equipment & Supplies
The ink cartridge wont come to center
Turn of printer. Turn it on, watch the carriage move, when it goes to the other side quickly unplug your printer, it should stop somewhere along the middle of the printer, now u can freely move it by hand to the position that you wanted, you can now remove the cartridge and replace it with a new one, after doing what you need to do just push the carriage towards the right side where it should be parked. Good luck!
Jan 14, 2010 | Dell Office Equipment & Supplies
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
Printer Wont print even with new ink
that means, 1 or more of the carts is showing low on ink or it might not being recognized. it might be the ink has a problem or the printer has a problem that it cant recognize the ink. try to Remove and reInstall Cartridges,
Press the nx200ug.1.106.4.jpg Stop button. The print head moves to the nx200ug.1.106.5.jpg position to indicate which cartridge is low or expended. Press the nx200ug.1.106.7.jpg Stop button again. If another cartridge is low or expended, the print head moves to the nx200ug.1.106.8.jpg position. Press the nx200ug.1.106.9.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. once you've identify w/c color has a problem, and removing and reinserting it does not resolve the issue, try another ink of that same color, if the issue persist, that means the printer is broken, call epson to get a replacement printer if it is with in 1 yr. from the date of purchase
Sep 15, 2009 | Epson Stylus C88 InkJet Photo Printer
Computer says black ink is low. Ink light is flashing on Epson Stylus NX100. When I hit stop button to begin replacement it wont move cartridge
***hi there,il be willing to help you on that. ****
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
2. Open the scanner and prop it up with its support.
3. Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
4. Press the Stop button again.
If another cartridge is low or expended, it moves to the position. Press the Stop button again to see if more cartridges are expended.
5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
8. Remove the yellow tape from the bottom of the cartridge.
9. Insert the new cartridge into the holder and push it down until it clicks into place
10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner
11. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
If the ink light flashes, press the Stop button and press down all the cartridges securely.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jul 13, 2009 | Epson Stylus NX100 InkJet Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
109 people viewed this question
k24674
jasbo
jasbo
