Question about Nokia N95 Cellular Phone
Nokia n 95
The connection hole that the charger goes into has broken so cannot charge phone or get charger to stay in phone. any ideas?
  • 3 Answers
Hi there cmsaby.
Well you could still get to charge your phone using the usb cable. Otherwise, you should use a universal cell phone charger. it sure is available evrywhere. I have one with two sliding connectors that should be adjusted to fit the + and - terminals on your battery.
Better buy an additional battery so that when you are using one, the other one can be charged.
regards.
veekram
Posted on Apr 12, 2008
Where does charger fit nokia 6300
I don't know if you have a Nokia 6300 or a Nokia 3600. But these images from the Nokia User Manual might help:
But I believe that both phones would charge through the USB connections as well.
Feb 20, 2013 | Nokia 6300 Cellular Phone
My phone want turn on even when its been charged
Try this:
Try charging your phone, see if the battery is charging or not. If it is, try turning on the phone. once opened, remove it from the charger, if it goes off, then the battery is broken.
If you connect your phone and it is not charging, there problem lies on the charger or connector of the phone/charger. Try using other charger, if it works, the problem is you old charger.
Try using other battery then open it, if it does turns on, your old battery is broken.
Thanks.
regards,
longgee
Dec 27, 2010 | Motorola Mobility Clutch i465 Cell Phone
3315 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Thanks
Sep 01, 2010 | Nokia 3315 Cellular Phone
Nokia 6500 wont charge
Where you connect your charger there is a loose connection there,what i can tell you for your phone to stay alive is just buy an universal charger it is not expensive,you put your battery in then after charging replace it in your phone and the problem is solve .
Feb 09, 2010 | Nokia 6500 Classic Cellular Phone
My nokia 5310, won't charge. I plug it into the wall, then it just stays there and nothing comes up with 'charging' like it used to before. I left it on charge overnight, but when I took it off charge the...
My Nokia 5310 also wouldn't charge; pocket lint had become trapped in the charging hole, and was packed down over time. I used a very thin straight-pin to gently scrape the lint out of the hole until I could see the gold-colored metal pad at the bottom (using a very bright flashlight and small dental mirror to direct the light). That took about 20 minutes. Now the charger plug slides all the way into the port and clicks into place. Tip: Be gentle, that center pin will break if you try to use something fat, like a safety-pin or a toothpick. -- John Dollison, Colorado.
Oct 29, 2009 | Nokia 5310 Cellular Phone
I just bought a KA08 KA09 mini mobile but can't get it to charge. After around a minute the light goes green & red saying okay but I get nothing on the screen? can you advise me?
Use a nokia charger, they fit but very loosely in the little hole next to the usb/charger slot. You lucky mate my charger exploded as soon as i plugged it in! Luckily my old phone was a nokia though.
Sep 13, 2009 | Cell Phones
Bad contact charger
This is a known issue with the Nokia 5310. The power port of this usually gets loose. You need to bring it to the registered Nokia Care Center for repair.
Apr 08, 2009 | Nokia 5310 Cellular Phone
Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
Mar 07, 2009 | Nokia N73 Music Edition Smartphone
Charging
your chargers may be broken or wires come lose in it or you could try moving the connection that goes into the phone around when its in there
Aug 25, 2007 | Sony Ericsson W200i Cellular Phone
Nokia N95 Cellular Phone Logo
56 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
