Question about Ruud UBHC Air Conditioner
Blower motor I have a UBHK 25J21SFE. The blower motor will ramp up and then shut off. It repeats this over and over. I have replace the ECM Interface board and still no change.
  • Gary Davd
    Gary Davd May 11, 2010
    is this a Variable speed model
  • 1,420 Answers
Hill, which blower motor? The exhaust inducer or the room air blower? If you are referring to the exhaust blower, check for a restriction in either the fresh air inlet, exhaust pipe or condensate line. If you are referring to the room air blower and you already replaced the motor, it is most likely a relay on the control board. You will need to replace the whole board. More info is always better!
Posted on Jun 13, 2008
Blower fan not working at all 2004 Buick rendezvous
Which system ?
HVAC Systems - Manual HVAC Systems - Automatic
If automatic it's probably the blower motor control processor .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, Blower motor speed signal, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module sends the commanded blower motor speed to the control processor through a 0 to 12-volt linear ramped blower motor speed control circuit. As the blower motor speed control voltage increases, the blower motor speed increases. The control processor sends the actual blower speed to the control module through a 0 to 12-volt blower motor speed signal circuit. The processor supplies 12volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Nov 19, 2016 | Buick Cars & Trucks
BLOWER MOTOR DOESN'T SHUT OFF
Hello, if the only way to shut off the motor is to turn off the main power then the relay on the integrated control board is faulty. You can try tapping on the relay to turn it off but eventually the board will need to be replaced.
Jun 04, 2012 | Amana Heating & Cooling
Blower motor will not shut off
Hello, sounds like the relay on the integrated board is sticking. The only option is to replace the whole board.
May 10, 2012 | Heating & Cooling
Carrier central AC/Heat system repeats "Replace
Try unplugging the unit and waiting a few which many times resets the board.
Aug 03, 2011 | Heating & Cooling
The blower does not turn on, so there is no heat. I don't know if its the blower motor that is out or if it is something else.
Hello. the first thing to check with a multimeter is if you are getting voltage to the motor, you should get 120 volts at the low speed motor tap on the control board and the neutral terminal. If not the control board is bad and must be replaced. If you have 120 volts there then the next thing to check is the capacitor, to check a capacitor you need to discharge it first and then set your meter to OHMS, and take your meter and put each probe of the meter to the capacitor terminals, the numbers on the meter should ramp up and down if not replace the capacitor. lastly if all that check out good then the motor windings are bad and the blower motor will need to be replaced.
Jan 31, 2011 | Heating & Cooling
I have a model ubhk. the ecm motor comes on and runs for a few minutes then turns off. then repeats the cycle. i have a constant 24 volts to the board.
The ECM motor is hard to diagnose unless you have a teat kit. Turn fan to on position and see if it runs, If it does the same thing bad module. Check all wires going to fab fro loose connections. russ
Mar 24, 2010 | Heating & Cooling
03 grand prix heater blower only works on setting #5
It needs a blower motor resistor which is located behind the blower motor - this is located on the passanger side underneath the dash board...it is round and black.
Jul 24, 2009 | 2003 Pontiac Grand Am
The model number as listed on the receipt is CKQ24. The Blower moter in the air-handler is not running. When the fan-only switch is turned on, the blower motor will attempt to spin by pulsing for about 2...
Personally I would get an exact replacement capacitor same voltage rating and microfarud rating. The capacitor will read something like 370v 5uf. I would be surprised if that's not the whole problem. If not it needs an exact evaporative fan replacement, and the new Capacitor. Happy cooling!
Jul 17, 2009 | Goodman CKL24AR24 Air Conditioner
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
Ruud UBHC Air Conditioner Logo
268 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
