Scanjet G4000 Since replacing my hard-drive can't get unit identified to function. Told unit not connected. Tried to remove program but failed ( Was told that solution to problem was to remove program then reinstall.) Solution would be greatly appreciated.
    Sergeant:
  • 221 Answers
Try just reinstalling without uninstalling first. Sounds like when you replaced your hard drive, that you did not reinstall the driver for the scanjet. The installation disk will have the driver for the device.
Posted on Apr 11, 2008
Pxe-e61
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 06, 2012 | Toshiba Satellite A135-S4527 Notebook
When i turn my laptop on i get this message PXE-E61 media test failed what do i do .. i have a lenovo g530
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the laptop, Windows installed and the laptop's device driversplus your programs etc. to get a functioning laptop again.
May 19, 2011 | Lenovo 3000 G530 Notebook
I am running Windows Vista; the device manager does not even detect cdrom/dvd drive; I reseated it and still nothing. Also when I tried running updates, my internet connection was disabled afterwards..I...
> does not detect CD/DVD drive
> diagnostic: replace hard-drive
> Internet connection disabled
Connect the CD/DVD drive to another computer, to see if it detected at start-up time.
Make a good backup of all your files on your hard-drive, before it COMPLETELY "fails" on you.
Use "Add/Remove Programs" to remove any update that may have "killed" your network-adapter.
Or, taken together, it's possible that your motherboard is "failing", and it's causing *ALL* the symptoms that you are reporting.
May 10, 2011 | Computers & Internet
My Toshiba Satellite A215 starts to boot but the hard drive never spins up. The screen remains black and it never goes into POST. I took the battery out and tried to run without; reseated the hard drive,...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 21, 2011 | Toshiba Computers & Internet
Computer will not start. I have tried a hard reset and cheked the ac adapter, which seems to be ok. I am being told it may be the motherboard. Since it was working fine one day, and then stopped...
this can be due to many reasons namely Power unit (PSU) failure, broken power switch and short circuits. see if your motherboard LED indicator light is glowing when you turn on power
Dec 14, 2010 | HP Compaq Presario F500 F700 and G6000...
My 320gb external hard drive has stopped working. I have used it alot with my laptop, but i hadnt used it for about a month. when i plugged it in it said it needs to install device driver software, but it...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, W.D. will replace it, at no cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program; buy a new unit from their web-site, and you can get a discount, as a previous customer.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
Oct 29, 2010 | Western Digital 320GB MyBook External USB...
I have XP and my WD hard drive will not recognize?
Try a different "data" cable between the computer and the WD unit.
Try connecting the unit to a different computer.
If it still does not work, then either:
* the USB-to-disk-drive adapter, inside the casing, has failed,
* the disk-drive, inside the casing, has failed.
Disassemble the unit, and remove the disk-drive.
Connect the disk-drive as a "slave" disk-drive to a computer, to see if the disk-drive is OK, i.e., the USB-interface is the problem.
Copy the serial-number of the disk-drive, and use it to "check warranty status" on WD's web-site. If the drive is still under warranty, WD will replace it.
If not under warranty, WD has a "Customer Loyalty Program", i.e., buy another MyBook through their web-site, and get about a 20% discount, as a current WD customer.
Apr 08, 2010 | Western Digital My Book Essential Edition...
How to program MP6 player
Goto start setting control panel (add & remove programs) uninstall
the software that drives your unit , after re-installing the software
your unit will have fresh drivers installed , follow the steps for
your unit and you'll be back using your device .
Feb 02, 2010 | Universal Office (MP6.0GB)...
HP Scanjet G3010 RE-INSTALL PROBLEM (WIN/XP)
hi hots2,
i ve been solving ur problem through live chat... when my power got cut.... pls respond to my omments to the chat.... u can go to ur "my profile" page and clik on the chat.... the entire transcript will be available.... though we might not be able to chat... we might still respond through comments...
thank you
May 04, 2009 | HP Scanjet G3010 Flatbed Scanner
How to recover data from a seemingly dead/non-functional USB flash drive
I own three flash drives, and follow this procedure. When you connect a flash drive, it should show up in "My Computer" as a removable drive - with a letter designation. Windows 98 requires driver software, XP and VISTA does NOT.
When you DISCONNECT the flash drive, you should "right click" on the drive icon, and select EJECT. The little light on the flash drive will go OUT, and THEN IT IS SAFE TO REMOVE IT. If you just pull the flash drive out without going through the disconnect ritual, you risk blowing the drive, and it is kaput. Doesn't always happen, but it can.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
David Payne
David Payne
