The DVD player in my 24" Toshiba Combo DVD/VCR TV is working intermittedly. It plays fine for a about 30 minutes ... then it stalls for a few seconds, starts again, stalls, starts again, stalls until it just freezes an image on the screen. Fast forward works, plays awhile and stalls again. At first I thought it was just a bad DVD but now any DVD I try has the same problem ... plays awhile .. then stalls. I have cleaned it with one of those disk cleaning applications with no help. Any suggestions?
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on Apr 11, 2008
    Master:
  • 788 Answers
Probably a missaligned head, not much that can be done without opening it up and checking the movement and the lense. Parts are probably impossible to come by. If it's not under warranty then you will probably be best to replace the entire unit unfortunately. Would probably cost more to have it repaired. Get the extended warranty next time.
  • 4,234 Answers
This can be either a dirty lens or the optics starting to fail. On very rare occasions it is the digital processing section. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that failes to correct the problem, try playing a music CD. If the CD plays OK, I'd suspect that the optics are starting to fail. Reading a CD takes a lot less laser power than a CD.
Keep us posted.
Dan
The dvd player says "incorrect
The DVD player is region locked and will only play DVDs from a particular region. The cheap DVDs are probably region 0 and so will work on any DVD player. You can scour the internet for a code hack to change the region (I've had a quick look and not found anything).
Feb 20, 2011 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Internal DVD not playing
Ur DVD drive said reading erorr,making clicking souond right?Take the tv aparts,take some Q tips,dip it in with some rubbing alchahol,clean the DVD drive laser eye should solved ur problems.
Apr 17, 2010 | Toshiba 24-Inch Flat TV/DVD/VCR Combo w/...
My toshiba tv/vcr/dvd combo wont play dvd's anymore. Is this worth getting fixed? Is there a warrenty for the dvd ? Or should I just buy a new tv and dvd ?
No. Usually it will cost you more money than gettting it fixed. If I make a suggestion. I would get a stand alone dvd, because if the dvd goes out in the television then the tv may not work.
Dec 26, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
20 INCH TOSHIBA DVD VCR COMBO, DVD KEEPS READING BUT NEVER DOES
I was having the same issue and I've been to several video stores to rent DVDs and 2 out of 3 rentals have the same affect where it is just 'reading' but even worse, it would play fine and then freeze up during the movie- very frustrating. Now, after 3 years of owning it, it died today. They just don't make them the way they used to :(
Apr 01, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Toshiba tv/ dvd /won't open
Unplug the TV ...wait 30 seconds then plug back in. Worked fine.
Nov 28, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
DVD PLAYER PLAYS BLACK AND WHITE
sir/maam it is possible that the DVD player is not compatible with colored tv,s or one more thing is kindly first adjust the screen focus of your tv,,,,thnksss and hope to help you!!!more power
Nov 25, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
