Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Freezer door does not seal all the way
I have had this Refrig for almost 3 years and have had a few issues along the way but here is the latest. Lots of frost build up and after a closer look, the door does not seal properly. You close it and it popps open from the bottom seal. Is there a way to tighten this or what is the best solution?
  • rkingtxtx Apr 14, 2008
    the seals are fine no issues. Just when you close the door is poops open from the bottom.
  • 86 Answers
Air intake has water in it (vapour) better if you higher altitude away from sea level.as the freezer gets cold it sucjks in warm air as a thermodynamic equilibrium mechanism. Only fix...get NEW seals or new door with new seals. Try thick silicone grease in a tube for cheap messy fix and rub it over the magnetic seals. dont use vasaaline, thats for gays.
Posted on Apr 11, 2008
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator keeps freezing. Temp stays at about 28 degrees. temp control on door (digital) and no matter how much you turn it up, temp stays below 30. Repair man came out and said seal was bad on...
Most likely one or both of the thermistors are bad. Usually pretty easy to find behind a vented cover about 2" X 1" on the side walls of the refrigerator and the top of freezer (if freezer is on the bottom of the unit)
May 31, 2011 | Refrigerators
I have a whirlpool refrigerator that is 3 years old the last few weeks it has been cycling on and off a switch or relay seems to be making the noise. Both doors are closed and seem to have a good seal....
your compressor is overloading, this is most likely due to low freon level,
you must have a service person look at the unit...
Please rate/vote this response. thanks
Dec 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My KSRS25ILBL03 side by side - the freezer has lots of frost, the bottom of the freezer if full of ice. I removed the ice (hairdryer), found the drain to the bottom pan frozen. Cleared that, & water...
main reason for lots and lots of frost is door seals not tight all round.look along the length of them to make sure and adjust by pulling/pushing into shape,also are the doors level???? would also cause doors not to be airtight.(adjusters/feet are under both outside corners).
Apr 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
Freezer on bottom is frosting up. Refrig was warming. We defrosted for 24 hours, checked the seals and replugged it in 24 hours ago. Already frosting over on the door. Thanks
We had this same problem a few years ago, we ended up having a service tech come to the house. It was the temp control in the fridge that wasn't working due to a broken part. $90 later - no problem since. Not saying it will be the same issue, but a service tech is probably your best solution.
Oct 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Maytab MTB2155BR Refrig that's leaking water. The freezer is on top and the water seems to be accumulating in the refrig section under the criper draws. Somehow it then leaks onto the floor. ...
Have you any tears in door gasket or do you see any way air is getting in the door through the door seal gasket?Is your temperature holding .Or have you had to turn it up??
Jun 18, 2008 | Refrigerators
Jenn-Air JFC2089HES Bottom freezer, French door:
You have a control board issue and should call out a tech. to do the repair. If your still with in your 1st year of purchase then Whirlpool should pick up the charges of part and labor. The tech. will need to be Whirlpool warrenty certified.
Feb 26, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
467 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
