Question about Intel Motherboard
Shutting down then starting back up whenever
Computer seem to shut down and start back at his own leasure.Changed PSU cleaned CPU fan and heat sink (sys temp 22c, CPU temp 46c). Disconnected all drives and still the same. It's a KM4M motherboard.
Can you help
  • 86 Answers
Ya. If it keeps re-booting then it may be a virus (my things virus)
If not, go to system properties and start up and recovery settings. remove reboot on error settings (in XP) It doesnt fix the root cause but may stop your frustration
Posted on Apr 11, 2008
Computer hangs after startup
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Dec 17, 2013 | EliteGroup K7VMM Motherboard
How to test cpu fan Dell 5100C
Check to see if there are any driver updates for your video card and sound card.
Jul 27, 2012 | Dell Computers & Internet
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
I turn on the computer and it may run some times for about 10 or 15 min. and then shut down i was wondering if i need a bio's update or what i have two hard drives in the computer xp pro on 1 and vista...
It could be overheating. After it shuts down, restart it, and enter BIOS SETUP, and look for a "PC Health" or "Status" entry on the menu. If you're lucky, it will report the current CPU temperature, and the speed of the fans, and the settable temperature at which it will shut itself down.
Check the capacitors on the motherboard -- any capacitor with a "dome" on top, instead of perfectly-flat, is a leaking capacitor that is intermittently failing.
Jul 19, 2011 | Mach Speed (MSNV-939) Motherboard
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
CPU over heats and shut down PSU. Already cleaned the heat sink and put new Thermal grease to it, it worked for about one hour and then it started again
Did you check to make sure that your CPU fan is running properly? if it sounds rough or noisy or becomes intermittent could explain your problem. "The brand of laptop also would be helpful"
Dec 19, 2010 | Computers & Internet
Half red ligh starts blinking then shuts off
Two possibility , first the 1of the heat sinks may have lost it's thermal seal
to the chips ie G.P.U. or C.P.U. this is more common when consoles
are played vertically . Second but less common the G.P.U. temp feed
connection has become intermittent and tripping a thermal shut down.
Remedy's are
Remove heat sinks for G.P.U. and the C.P.U clean off the old heat sink
compound and replace with new ( articsilver 5 ).
If the console still over heats ( two red lights) then the G.P.U C.P.U
will need to be re-flowed back to the board that normally corrects
the problem in 90% of over heating problems.
If you have any questions feel free to ask.
Rob
May 02, 2010 | Microsoft Xbox 360 Console
Computer shuts down after 15 mintues or so. Replaced power supply, so thats not the problem. After 10 mintues computer might come back on. Sometimes the fans will come on and nothing else. It very...
Will it run in safe mode? If so, then the problem is software.
If not, you most likely have a heat problem. Blow all the dust out of the fans and the CPU heat sink.
Not knowing how old the computer is, whenever I see a time-related problem like this I suspect heat build-up.
I'd even go so far as to take the heat sink off of the CPU, apply heat sink paste, and reseat heatsink and try to start it again.
Oct 22, 2009 | Compaq Computers & Internet
Pc shuts down ,reason cpu overheating
It seems to me that your pc is facing hardware problem.It is suggested that you contact local computer service to replace the faulty hardware..
Jul 25, 2009 | Computers & Internet
Dell 5150c shuts down orange flashing light
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Mar 16, 2009 | Dell Dimension 5150C (DIM515CMIN) PC...
Intel Motherboard Logo
149 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
