Question about Refrigerators
Fridge is making loud noise and icing up. - Refrigerators
  • Anonymous Oct 05, 2008
    Hi
    my fridge freezer making a loud noise,
    i have previously turned it off and it was temporarily solve the problem but the problem re-occured, make of my fridge freezer is Oceon, please find me a solution as i can't effort to buy another right now.
    Genius:
  • 1,073 Answers
Check your freezer coil located behind back wall of freezer if it is frozen up you have a defrosting issue
Posted on Apr 11, 2008
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Ice maker makes knocking noice
It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
May 19, 2012 | Electrolux Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Apr 05, 2009 | Kenmore Refrigerators
Ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Refrigerators Logo
355 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
