Question about Samsung Impax 210 APS Point and Shoot Camera
Samsung Impax 210i Camera
One day I went to use my camera and found it is locked. I changed the battery. The date and time are correct. The film is stuck on number 13.
  • queenbutter Apr 11, 2008
    The camera is around 3 years old. Rarely used.
  • 555 Answers
When this happened in my camera, it meant that the film winder gear was stripped. How old is this camera?
Posted on Apr 11, 2008
  • Matt Jurach
    Matt Jurach Apr 11, 2008
    The good thing about film cameras is that they are repairable. Digital cameras are usually either working or thrown away.
    The bad would be that repairs are sometimes not inexpensive. In my case, the bill was almost $200. The gear itself is cheap--it's the labor involved in disassembling the camera body just to replace it and put everything back together...
Dead battery
Yes, there is almost always a secondary battery for things like the time and date, they usually do not make it easy to get to this battery. For a point and shoot you'll need to take apart the camera.
NYC Photo Safari
Apr 15, 2014 | Samsung Maxima Zoom 105GL 35mm Point and...
Samsung ES30 just will not power on
I have similar problem with DiMAGE 7. Even when I use AC adapter the only thing that happens is a low-charge battery image in the display.
Iguess there is an internal battery that keeps the time/date going when the regular power supply is off. The quesrion I have not found an answer to is can I replace the internal battery myself? Or is something else wrong?
Nov 04, 2012 | Samsung ES30 Digital Camera
Polaroid Time-Zero Pronto AutoFocus is not ejecting film when shutter button pressed
This camera appears to be some 40 years old now, so spares and service are unlikely to be obtainable. Why not replace it with a more up-to-date digital model ?
Sep 09, 2017 | Polaroid Photography
Lock broke an door for film
Look on Ebay for another one. Either use the new one for parts(unless it works fine) or use it as your main camera and keep the parts one for spares.
This might be a good time to switch to 35mm.
Oct 19, 2009 | Samsung Impax 300I APS Point and Shoot...
Need to reset time and date every time I turn on camera.
The backup battery needs to be replaced. This small button battery (CR1220) provides the power for your camera to 'remember' settings when you change or remove the AA batteries. Instructions for changing this battery are in the manual on page 191 (US version of manual).
You can view/download the manual here.
Sep 08, 2009 | Canon PowerShot SX100 IS Digital Camera
Did you try this?
Well I have had similar problems with this camera model. I tried several types of batteries and changed the battery type settings from the menue too... the problem changed a little bit but it did not solve the issue. I send the camera to Samsung service but got it back with "no fault found".
as I am working in this business I could not believe that a camera like this is not able to make less than 10 pictures with one set of batteries....I gave not up.
here is what I found:
when you open the camera by releasing the little screws from the buddy you will find several connector clips holding flatcables. this clips have not been closed correctly. just close them carefully!!! with a forceps and you will have a nice camera! this work can't be done in take your time.
Oct 30, 2008 | Samsung Digimax D53 Digital Camera
Set time/date on Argus APS 400
I continued to push other buttons on the camera while the date or time was flashing untill I found that the mode button made it change.
May 21, 2008 | Photography
i went to the public library and got a copy of the manual
Apr 05, 2008 | Konica Minolta Maxxum 5 Date with 28-80...
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Samsung Impax 210 APS Point and Shoot Camera Logo
91 people viewed this question
Top Samsung Photography Experts
Tom Chichester
Are you a Samsung Photography Expert? Answer questions, earn points and help others
