I inspected a home that had a amanda furance (central) with seril # 8604103099 could tell me what year it was made? Thks Btruegrits37@aol.com
  • 30 Answers
2004
Posted on Apr 11, 2008
1 want the smiley central icon to come back on my aol 9.1 toolbar. I don't understand how i lost it again !?
To enable Smiley Central, go to your Internet Explorer web browser -> My Web Search-button -> Enable/Disable Features -> Check box "AOL Instant Messenger" -> Save changes.
In order for the changes to take effect, close AOL Instant Messenger, and reopen it again.
Mar 17, 2011 | Microsoft Windows XP Home Edition
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
We modular home in 2008 with a coleman furance model number DGAA090BDTB we have had nothing but trouble with the furance, the latest thing we found out the heat exchanger was cracking. We have had...
if the heater is a 2008 also then there should be a warranty still on the heat exchangers, i have installed modular units such as coleman ,intertherm, and nordyne common modular home units inthe past and at minimum the heat exchanger should have a manufacture warranty of at least 10 years on it... and up to 20 on the heat exchanger not exactly sure what the warranty is on this but can guarentee it should have at least a 10 year warranty...call manufacture with your model and serial number and they can give you warranty...then get a reputable company out to do the repairs...good luck to you that really stinks
Jan 08, 2011 | Coleman Heating & Cooling
Heater ignition for roofmount air furance carrier
check hot surface ignightor or pilot and all limit switches make sure filter is clean
Oct 21, 2009 | Heating & Cooling
Smiley central
Uninstall & reinstall your AOL 9.1 software from the system & then reinstall it... it should work.. .as most of the times... So just try that the link to reinstall AOL 9.1 is
http://daol.aol.com/software/91
Jan 20, 2009 | Microsoft Windows XP Home Edition
Weather King Furance
Hi Cableman. Any 24-36" thermocouple wll work and can be found at your local hardware store.
Hope this helps,
RepairUSA
Nov 05, 2007 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
