Question about Samsung HCM4216W 42" Rear Projection Television
Turns off and on repeatedly..
TV was working fine then this evening when I tried to turn it on, it acted like it was coming on then turned itself off...back on...back off...several times...all the while the little red light beside the power button was blinking. What could this be Every time I try to turn the TV on, all I see is the red timer light blinking ten times, then it stop blinking, without showing any picture at all, I removed the video card, and the blinking on the timer light stop stoped completely, so just installed back the video card, and it went back to the timer light blinking
    Master:
  • 788 Answers
By video card do you mean a Cablecard? I've heard of problems with Cablecards causing problems with the host television. Contact your cable provider about their card. Check to see if the TV works with other inputs without the cable card installed.
Posted on Apr 11, 2008
  • Samsung Master
  • 19,396 Answers
Probably it is the poer unit
  • Ginko
    Ginko Apr 11, 2008
    You have a problem with power supply, or a short inside tv. the tv switching off by itself it is because of a safety switch preventing the tv from receiving eventual further damage.
    Probably changing the power unit inside the tv may fix the problem. It should be tested and eventually replaced.
    Unless you are an expert DIYer you should call a service center in your area and have the tv repaired.
    Regards
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
Technika Tv is receiving power and is trying to switch itself on .the standby light turns green for a few seconds and then goes rd . this cycle repeats itself constantly. Tv will not switch on .
There is some short circuit inside any one of the circuit boards. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Feb 26, 2013 | Televison & Video
Tv turns itself off
do the self test the set has.
when green light (power) comes on and then goes off, press and hold BOTH the Menu and Input buttons for at least 5 seconds and release both buttons on the front of the set.
The power light will display a error code: for example 2 blinks, a pause and 2 blinks (this is the most common one) and it will repeat the code about 5 times.
To get it to repeat it you have to unplug set, plug it back in and turn it one and when it fails repeat the check.
Let me know what error code you find and I will tell you what may be wrong. I hope it is 2,2 as it is the least difficult to resolve.
SD TECH
Jun 16, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
TV turns itself off.
Check for a loose wall outlet. try plugging it somwhere else. that happens to me many times. it is not your tv.
Aug 04, 2009 | Televison & Video
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
It turns itself on and off repeatedly
Try this:
Unplug the tv let sit for a minute while you replace the batteries in the remote and cover the IR remote sensor on the front of the TV. Cover it with a piece of black tape or a piece of aluminum foil.
Plug the tv back in and turn on.
If it no longer turns on and off by itself then you have IR interference from some other remote operated device in the room.
If it does continue to turn on and off with the IR sensor covered then it is the internal wiring/processors and will need servicing.
May 12, 2009 | Sanyo DS27510 27" TV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
244 people viewed this question
Henry  Thomas
Henry Thomas
