Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
No magenta I have a brother mfc440cn. When I try to print out a test page I only get 7 small broken up lines. I have ran it through the cleaning cycle over a dozen times and still no better. Is there anything else I can do?
  • susieq57 Apr 12, 2008
    Thank you Mix-it-up. I do use generic ink and I did purchase all original brother ink. I tried running it through the cleaning process 8 times and still nothing. Is there anything else I can try beside taking it in for repair?
Hey im jose and i have a brother MFC-440CN printer and ever time i trying to install the printer in to the computer but i have no CD program for it ......can you help me ..?
Posted on Apr 14, 2008
  • 832 Answers
Do you use generic ink? If yes, use an original brother ink cart! Because of the additives within the brother ink, cleaning substances will keep the ph clean.
If you still have trouble please post again here
Posted on Apr 11, 2008
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
When printing lines are running through the sentences.I have a brother mfc440cn printer
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Brother mfc440cn one color not working
Change the roller and frame of the printer it seems it is blocked by particules
Sep 01, 2009 | Brother MultiFunction Center MFC-440CN...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Will Not print magenta
hmmm...even on a test print page?
Feb 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
MFC440CN PRINTING - ALL BLACK
I understand that the machine is printing only in BK. You have lost color.
If so, do run the cleaning cycles several times and run quality check test prints after each cycle.
There should be color again.
Otherwise the ph is defective!
Feb 11, 2008 | Brother MultiFunction Center MFC-440CN...
My printer doesint print magenta on test page
Did you use third party ink? Insert a genuine (original) brother ink cart and do the cleaning twice. there should be magenta again. If there is no magenta after that, this could be either because of air in the system (thats why you should do the cleaning twice!) or the nozzels are clogged (and cant be cleaned anymore).
Sep 11, 2007 | Brother MFC-620CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
