Printer keeps telling me to press enter to align cartridses
I put in a new print cartridge yesterday, it printed some stuff i had put in before it would not print before the new cartridge, I mad a couple copies then it said press enter to align cartridge. That is all it will give me, I guess I have run that 10 or 12 times then it says the same thing again. What do I need to do?
Joyce
  • jntbrd Apr 13, 2008
    It is hp officejet v40 all in one printer fax copier scanner
  • stephen Vasquez
    stephen Vasquez May 11, 2010
    What type of inkjet model of HP is it?
Same issue on G55, I wiggled the ink cartridges in their tray and I got the error to go away. Squeeze them together at the top of each an notice the flex.  Un-brand ink cartridges.
Posted on Apr 13, 2008
  • 45 Answers
This happened to me with an HP psc 2110. What it had come down to was the Scanner could not find 'home". Under the platten or the glass there is a scanner that moves from left to right. This "reads the white strip that is there(you cannot see it due to the molding that covers the area also it is located on the underside of the glass). This needs to be cleaned as well as the mirrors of the scanner itself. I have performed this many other times with other HP type scanners of this nature. This is something that is left to the tech's that know how to take them apart. I say this due to the hidden plastic clips that are recessed within these machines.If you are too heavy handed,they will break. But the cleaning of these areas will get rid of that error code,Good Luck, Best Regards,Steve
Posted on Apr 14, 2008
Printer hp 2210 always says Press Enter to Align Cartridges. When I press enter it aligns and than says the same thing. When I try to print it won't print from the email or when I'm on line. When I press...
You press Enter , but the error message does not go away ? You have to bypass the cartridge alignment -
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
My printer wont print it keeps saying press enter to alein cartridge
I just noticed in the link to your forum item that additional text appears that does not appear in the item itself. It looks like you are getting a message telling you to press Enter to align your print carriage. This is a common step after you replace an ink cartridge. According to HP.com, here's what you are supposed to do:
"A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete".
The link to those instructions is as follows:
Replace the Print Cartridge
Just follow the instructions I posted above in italics and you should be good to go. Good luck.
Oct 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
206 people viewed this question
jasbo
jasbo
