Question about Altec Lansing Multimedia Computer Speakers
Controller for Altec Lansing XA3051
I need to replace the wired controller to my son's 5:1 PC speaker system.
Without it the speakers are useless but even more so is the Company. They say they don't carry any more parts and have no more information about this Model. I bought it almost 2 years ago. If I had the plug ID # to the end I can repair it myself. But the Tech guy at Altec said they don't even know what part that is.
PLEASE HELP
Mike
whiteclaw1956@comcast.net
  • arbame Mar 17, 2009
    the controller was short circuited. I need one . can you help?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
If you plug it in to your computer, a freeware program may still be able to recognize it and give you exact model numbers and IDs--worth a shot, and you'll love the program anyway--Belarc Advisor. It lists all hardware and software, model numbers, keys, etc. Hope it helps.
Posted on Apr 18, 2008
  • Richard Roberts Apr 18, 2008
    PS--the least hassle may be to buy used on EBay. One is for sale for buy-it-now for $45 with shipping as we speak.
    I found the user's manual athttp://audio.manualsonline.com/manuals/m...
    It is fairly useless. The only troubleshooting tips for "Controller
    doesn’t work" are:
    "Verify that the grey-colored DIN connector is firmly inserted into the DIN connector jack on the subwoofer.
    Ensure the pins are aligned between the plug and jack.
    Remember, the arrow should be facing up."
    Perhaps your arrow is not facing up. Hmmm.
7 WIRES , WHAT COLOR GOES TO WHICH PIN? 2 BLACK , 1 GREEN, ONE YELLOW, ONE WHITE, 2 ORANGE, ONE HEAVIER THAT THE OTHER
Hi Jerry
What Model....?
Using a mobile phone camera would have helped in this situation.
Before taking things apart
I'll be very surprised if someone has the same speaker system in bits somewhere
An electronics guy would trace the wire back to it's source to decide what it's being used for.
Good Luck
Review Altec lansing BXR1220 Speakers 8
Altec Lansing Avs300 PC Speakers Sub
Sep 13, 2015 | Altec Lansing Audio Players & Recorders
Altec lansing mx5021 wired controller not working
Sounds like you might have a wire loose at the other side of the controller. This is a easy thing to find out. Just unscrew the side screws that hold the back board to the cabinet. Don't unscrew the screws connected to the speaker wire clips unless the back doesn't come off. Just look for a disconnected wire at the controller jack then put it back. If there is no loose wire then you might have a bent female contact at the outside of the controller jack. You would have to look for this looking into the holes where you plug the cable into the controller jack. If you see a bent contact then use a thin nail of ice pick and insert it into the hole where the bent connector is to try to re open the contact so the cable can slip into it easy. Don't forget to unplug the power first.
Nov 07, 2013 | Altec Lansing MX5021 Computer Speakers
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Vs3251
You may be out of luck. Apparently, Altec is no longer supporting this product (2002) and the user's manual provides no specifications for the power supply. You can try asking them at 1-800-ALTEC-88 (1-800-258-3288) or Email: csupport@alteclansing.com
The manual is at http://audio.manualsonline.com/manuals/mfg/altec_lansing_technologies/xa3051.html
Mar 08, 2008 | Altec Lansing Multimedia Computer Speakers
VS-2121 altec Lansing - ORANGE BIG FAT CABLE MISSING TWO MIDDLE PINS
well u could try a shop that sells music equipment they should be very common... but u need to know how to solder :D or at www.aswo.com i think they have cables....
Jan 19, 2008 | Altec Lansing VS2121 Computer Speakers
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
1,170 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
