FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Microwave not working (by 2 users)
posted by t1nkerbelle on Apr 11, 2008
The microwave suddenly will not work. The clock is on, the interior light works but the only key that makes a noise is the stop/clear.I thought it accidentaly was locked and tried holding numerous keys- the stop/clear key eventally put a little L on the screen even though the lock sign is on the start key. I tried unplugging. I have not figured it out + I no longer have the manual since I've never needed it in the 8+ years I've had it.
My microwave isn't working right. Everything works but the turntable doesn't move, and there's no sound at all when i tried to heat something. Also no heatng. It all happen after I cleaned it. I'm not sure what to do.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ccharris, posted on Apr 11, 2008
All the buttons appear to work and a setting can be made for temperature and cook time. Light goes on inside when door opens and for all it appears the microwave works. However the turntable does not turn, there is no sound and food does not cook. The microwave was in the house that I purchased 3 years ago and there was no manual with it. I have tried unplugging/plugging in tried different buttons and have only been able to use it for the timer and clock to get any use at all.
Solution #1
posted on Apr 12, 2008
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2728 votes
It might be helpful to tell us the brand and model number, but I think I can answer this one either way.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Spacemaker (JVM1640SJ) Microwave Oven GE JVM1850 1000 Watts Microwave Oven GE General Electric Advantium SCB1000M 975 Watts Convection / Microwave Oven GE Advantium SCA1001SS 900 Watts Convection / Microwave Oven GE Advantium SCA2000B 950 Watts Microwave Oven GE Advantium SCA2001BSS 950 Watts Microwave Oven GE JE1660 Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
no manual and do not know to...
I have a Black & Decker... Answer This...
Microwave Ovens
The Mirowave, Convection...
The Mirowave, Convection... Answer This...
Microwave Ovens
How do i change out
How do i change out the control... Answer This...
Microwave Ovens
Sanyo Super micowave &...
Sanyo Super micowave &... Answer This...
Microwave Ovens
Dear Mrs / Mr I Have
Dear Mrs / Mr I Have Bouth A... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
