Tv not turning on
when we try to turn on the tv it does not turn on the button will blink and it will click but not come on when it did come on today there was no sound. we turned it back off and it took forever to come back on then it came on the way it was supposed to. Pleasel help us find the solution to our problem
    Genius:
  • Televison & ... Master
  • 1,673 Answers
Powe supply, and or scan circuits failure. The set will have to be serviced by a qualified service center. Get an estimate to see if the set is worth servicing. It may be time to buy a new one.
Jerry G.
Posted on Apr 11, 2008
TV will not turn on-- clicking noise in the back
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Nov 15, 2007 | Panasonic PT-50LC13 50" Rear Projection...
My Mitsubishi TV has been working fine. Today I pressed the power button and the light came on and then clicked off about two seconds later. What can be done about this?
This will tell you what kind of problem you have:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
sd tech
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The TV was working great yesterday, but today, when you press the power button, th TV clicks on, then within 5 seconds clicks off, picture never appears but green light comes on until TV clicks off. ...
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Sep 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV34HS510 always worked perfectly but today it wouldn't turn on by remote or button on TV. It makes the same "click" sound which it always did before coming on but it just immediately clicks again to...
You need to bring it to a TV technician. There is a relay inside the TV which can be blocked by any few errors that may occur in your TV, for protection. Only a tech may discover the problem.
May 25, 2009 | Televison & Video
TV won't turn on. (Panasonic 1080i HDTV)
The power led blinking is an error code if you can reply to this same post and let me know the number of blinks I can assist you with what it means.
Jan 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
