Question about GoVideo VR3845 DVD Recorder/VCR
"safe" keeps me from opening dvd tray manually (must use remote control)
Suddenly, the word "safe" appears in the readable area and I cannot open the DVD tray manually. Must shut the recorder down and then press "eject" on the remote in order to open the tray.
What do I do to remove the "safe" mode?
I unplugged the recorder for 10 seconds, replugged it in and voila, the problem was solved.
Walt in Indiana
Posted on Apr 12, 2008
CHANGE REGION RHT390H
see this steps:
Turn on the DVD player.
  • 2 Open the DVD disc tray and keep it open. Power on your DVD player and open the disk tray. Leave the tray open as DVD region code hacks need the tray to be open as the code is entered for it to get activated.
  • 3 Press the "Home" key on the DVD remote.
  • 4 Select the "Setup" option.
  • 5 Select the "Lock" icon by using the arrow keys on the remote control.
  • 6 Press the number key "0," seven times on the remote. This is the code-"0000000."
  • God bless you
    Jul 16, 2012 | LG Televison & Video
    Tip
    INITIALIZE THE DVD PLAYER -FIRMWARE UPDATE
    FIRMWARE UPDATE
    1. Turn the power on and remove the disc on the tray.
    2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
    The DVD player can also enter the version up mode with the tray open.
    3. Load the disc for version up.
    4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
    5. After programming is finished, the tray opens automatically.
    At this time, no button is available.
    6. Remove the disc on the tray.
    How to Eject Manually
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
    http://electro-medical.blogspot.com/
    on Jan 19, 2016 | Denon DVD-1740 DVD Player
    Tip
    Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
    Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
    1. Press the Standby button on your remote control to place the unit into Standby
    2. Press the Standby button on your remote control to turn on the unit
    3. Press the Open/Close button on your remote control to open the drive tray
    4. Press the Clear button on your remote control
    5. Press the 1 button on your remote control
    6. Press the 3 button on your remote control
    7. Press the 6 button on your remote control
    8. Press the 9 button on your remote control
    9. Press the 0 button on your remote control
    10. Press the Open/Close button on your remote control to close the drive tray
    11. Press the Standby button on your remote control to place the unit into Standby
    12. Press the Standby button on your remote control to turn on the unit
    Your DVD / VCR combo is now region free.
    __________________________
    Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
    on Apr 07, 2010 | Televison & Video
    Unlock toshiba SD800ky
    1. Power on the DVD player
    2. Press the Open/close button on your remote control to open the drive tray; remove any disk and leave the tray open.
    3. Press 2,4,0,3,9,6,0
    4. Press 9 for multi-region playback. You will see a "9" appear in the upper right hand corner of the TV. DO NOT Press Enter button on your remote control
    5. Press the Open/close button on your remote control to close the drive tray, and power off the DVD player before it says "no disc".
    6. Power the DVD player back on and it is region free !!! Woohoo !
    Jan 09, 2010 | Televison & Video
    Need manual for Duraband DVD 1002 D seri
    1. Power and switch on the Durabrand DVD player.
    2. Open the DVD disc tray tray or lid.
    3. Press Stop.
    4. Press 3 – 5 – 9 – 7 (3597 in sequence). Can be done on remote control.
    5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
    6. Press OK.
    7. Close the disc tray and press Standby on the DVD player front
    Sep 11, 2009 | Durabrand DVD-1002 DVD Player
    Locked dvd tray.
    Press Setup then the numbers 2 0 0 5 then setup and it should unlock
    or
    Display 2 0 0 5 Display
    Dec 22, 2008 | Toshiba SD-K760 DVD Player
    Locked dvd tray.
    with the unit off press and hold the stop button and the eject button.
    Jul 08, 2008 | JVC TH-S11 Theater System
    Can't play region 2 dvd's on my player
    Newer DVD224 is actually DVD-224ss - small print on front of manual. There are two possible hacks:
    DVD224SS (This worked for me)
    1. Open the DVD tray
    2. Press STOP button on the remote control
    3. Press 70
    4. Press MENU
    5. Use the numeric keypad to select your region code number (0 – 6).
    OR
    DVD224 (224SS)
    2. Press STOP button of remote control
    3. Press the digit number buttons “2008” of remote control.
    4. Press MENU
    Region code will appear, select your region code number.
    Jun 22, 2008 | Coby DVD-224 DVD Player
    Regional code
    open tray
    Press PAUSE
    enter 0000
    The region code set page should appear.
    Set code. 0 for multi region
    Press PAUSE.
    OR
    Make sure your TV is on and the DVD player is active on it
    Unplug the DVD player
    plug it back in
    wait for text "nodisc" to appear on the DVD display
    Use remote control to open tray (tray must stay open)
    Use remote control to Press "Pause" (you won't see anything)
    On the Remote control number pad enter the number "0000" (4 zeros)
    The region code setup window will appear on your TV
    on the remote control number pad enter number "0" (zero)to set multi region
    Use remote control to Press "Pause" again
    close tray
    Jun 06, 2008 | LGDVB418 DVD Player
    Toshiba SD-K760 region codes.
    I found this on another site, worked for me, hope it helps...
    icon_minipost.gifRegion code hack posted by Stratos, April 30 2006:
    1. Press the Open button on your remote control to open the drive tray
    2. Press the 2403960 button on your remote control
    3. Press the 1 button on your remote control to change the region to 1, 2 for region 2, and so on, or 9 for multi-region playback. New region number will appear on screen.
    4. Press the Open button on your remote control to close the drive tray
    5. Power off the DVD player
    6. Power on the DVD player
    Jan 17, 2008 | Toshiba SD-K760 DVD Player
    GoVideo VR3845 DVD Recorder/VCR Logo
    156 people viewed this question
    Top GoVideo Televison & Video Experts
    Demonic-2011
    Demonic-2011
    Computer Repairing
    Computer Repairing
    Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
