Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Spin=wet drippy clothes
My washer spins, but leaves clothes wet & drippy, plus shakes so had the front plastic panel on door Fell OFF...Just went out of warrenty...mostly a piece of **** since I purchased!! Frustrated!!
  • 487 Answers
If it shakes so hard it makes me wonder if one of the dampners is lose. If yo haven't moved it and it normally worked ok than that will be the thing. It leaves it wet because the machine cant get to the high rpm's because of imbalance
Posted on Apr 17, 2008
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore front load washer model 41744052500 the other day i did a load of wash and when i went to the drain cycle it worked fine but whenit went to spin it went right a couple of times then left...
tub was out of balance remove some of the heavier clothing and re spin! and in the future donlt try to run so much through it that are heavier items when they are wet
Jan 12, 2010 | Kenmore Energy Star 44092 Front Load...
Mav7000 spins but does not extract well. Clothes remain wet
wet as in standing water left in tub, or wet as in extra drippy???
standing water would be bad or pluged pump, drippy would be bad belt, pulley or tensioner assembly..
also if pump turns hard or has seized, the seal/bearing may have seized, causing a slowdown in spin speed besides burning the belt, leaking, and making a mess..
best of luck,
ttfn
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
The washer will not spin and the load of clothes is still wet it clicks on and off within 1 minute and the door is not staying locked
i would consult the technical papers within the lower unit, but i believe if the door latch is not locking, or otherwise broken it will not enter the spin cycle therefore leaving the clothes very damp indeed.
best of luck,
ttfn
Oct 22, 2009 | GE WSXH208A Front Load Washer
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
Sep 18, 2009 | GE Washing Machines
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
171 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
