Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker not making ice
The water in our neighborhood was turned off for about twelve hours the other day and since then our ice maker will not make ice. Any ideas?
    Genius:
  • 1,073 Answers
Check the fill ube that is behind the icemaker that puts the water into the ice maker, the tube could be frozen with ice
Posted on Apr 11, 2008
We recently had a water supply connected to our Whirlpool refrigerator model GB2FHDXWB02. After ~ 18 hours no water has entered the ice maker? What is the problem? Can I manually initiate water going into...
Make sure you actually turn the icemaker on, there is a arm that you have to trip in side that will activate the solenoid that make water enter the ice marker. Also keep in mind that the air in the line has to work out so give it 24 hours to make it to the ice maker. You should see the hose in the back of the frig, that runs from the solenoid to the ice maker. Also check the ice maker itself to make sure it is plugged in completely. Good luck
Jan 09, 2015 | Whirlpool Refrigerators
DC33 PA 1A
If the machines ice storage capacity is 26 lb per a day then that is all it will make in a 24 hr day Now this depends on water temp entering the machine, the ambient temperature around the machine and the condenser coil and fan is not dirty. Now the machine is capable of making 33 lb of ice in a 24 hour day but the storage bin capacity is only 26 lb if you don't remove any ice it will make only around 26 lb and shut off until it melts and causes the ice maker head to start.
Nov 26, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
No water flowing into the ice maker reservoir. I poured water into the reservoir, but no ice dropped after 10 hours. Next day I unplugged refrigerator opened freezer door and thawed it out for about two...
Well, if the ice maker were working properly, when you poured water, assuming you poured A, enough water, and B, not too much water, you should have seen some cubes drop into the bucket. But since you did not get any ice cubes, I would have to say the reason your ice maker is not making ice is because you have a bad ice maker. Its not receiving water because it is not cycling.
Oct 09, 2010 | KitchenAid KSRU25CR Side by Side...
Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
May 19, 2009 | Sub-Zero 561 / F
Ice Maker
Check the back of the icemaker & verify that the icemaker was plugged in. Check that icemaker is turned on. Check that the water supply was not turned off. Check the water supply tube at the icemaker for ice blockage if the water supply is blocked cleared the ice away. IF Ok with both items checked. Then pull the plug on the refrigerator for about a minute, so that it can reset itself. If you still have no ice within the next twelve hours then the problem will either be with the inlet water valve or the icemaker itself. However, I really doubt that since it worked prior to service. I'm pretty sure it has to do with the first steps mentioned. Hope this helps. Please post your findings
May 05, 2009 | Frigidaire FRS26ZSG
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
rugby prop
Lawrence Oravetz
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
