Question about Dryers
I need to replace the 4 cord dryer plug that is currently on my dryer with a 3 cord plug because the plug that is in place has 3 receptacles. the replacement 3 prong plug that i bought is not color coded. how do i install it?
    Genius:
  • 1,073 Answers
Lay the cord down flat the center lead of the cord goes to the center screw of the terminal block, connect the left lead to the left tern=minal and the right lead to the right terminal
Posted on Apr 11, 2008
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Tip
Rewiring 4 to 3 wire plugs Information.
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
on Feb 09, 2010 | Washing Machines
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 13, 2011 | Dryers
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
What type of power cord ( 3 or 4 prong) for an electric dryer
Hello markdraghi,
I assume ( but don't know) that you are replacing an existing dryer... That said, then you need to match the cord ( 3 prong or 4 prong) with what you currently have for a receptacle. A 3 prong uses two hot feeds ( red and black) and a Neutral ( white). A 4 prong uses the same as the 3 prong but also includes a Green wire for Ground. Get back to me if you need wiring details or if I have NOT answered your question. Hpe this helps.
Regards,
Rick
Jan 04, 2009 | GE DBSR453EBWW Electric Dryer
Dryer 4 tp 3 pring cord install
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Regards,
Rick
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
91 people viewed this question
Top Dryers Experts
