Question about IBM Infoprint 6500 Matrix Printer
Ipds error message
I A MGETTING A ERROR MESSAGE:
ENET IPDS 87% MESSAGE
ANY IDEA WHAT THIS MEANS ?
Dash displaying random error messages and very keen immobiliser
Get a scanner from IPD and that will tell you what is wrong as well as give you the ability to clear any codes.
Foxwell NT 300 Diagnostic Scan Tool
Apr 04, 2013 | Volvo S40 Cars & Trucks
How do I transfer messages off my blackberry? (storm 9530)
Use your bb desktop software to make a backup onto your PC. It will make 2 files, with today's date, one a .cab which contains media files (eg photos you took) and the other, an .ipd contains encapsulated application data.
The contents of email are in in the .ipd file, in bare text html format. Suggest taking a copy of the .ipd file first, then open the copy in your favourite text editor. Notepad is OK; I use EditPad Lite. Then do a text search for "<html" (without the trailing ">") to find the first email message. You can copy the html between <html ...> and </html>, paste into a new text file, edit if you want, and save as SomeFileName.html, then open in your browser to see it.
Between each email is some binary info that would be used by the blackberry. Don't know how to decode this.
Some emails are text only. SMS messages are in there too - can search for the text you know is in one of them, to find them all together, the message itself is bare text.
I like helping people with blackberry, because I learn useful things for my own use. Just found this product, shareware for about US$20 after 30 day demo trial:
http://www.processtext.com/abcblackberry.html
Handles IPD files.
Sep 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
87 dodge aries k car
15 is vehicle speed sensor. 22 is coolant temperature sensor.
55 is end of codes or end of message.
Jan 01, 2009 | 1987 Dodge Aries
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Help Toshiba E-Studio 162 Copier error
how can I reset the Toshiba estusio162 without calling for maintenance
Sep 03, 2008 | Toshiba e-Studio162 Copier
Acer eNet Management
Do you have "What do you suggest I do to stop the alternating messages? It's almost as annoying as popups." I get an alternating popup (actually fade in fade out) message. the alternating message says "Acer eNet Management Internet Disconnected" Here is my solution!!! :)
First 'Right-click on task bar', TASK BAR IS AT THE BOTTOM OF YOUR SCREEN' then click on 'Properties'. Click on 'Notification Area', Click on 'Customize', Look for WLAN(disconnected), Click on it and choose 'HIDE', Click 'OK', then click 'APPLY', then click 'OK' and now you have no more annoying message. TOO EASY MATE ;)
Jul 25, 2008 | Microsoft Office Outlook 2003 for PC
Enet service
The eNet service is an Acer-specific connection management program. For some reason the service has stopped running. You can check its status through control panel.
Go into Control Panel and from there into Administrative Tools. The Services list is there. You might need to check that it's set to start automatically, and that it is running. If it's not running, start it and set it to start automatically. If it seems to be running, restart it and see if you get any error messages. If you get error messages, post a followup comment on this ticket and I'll try and help further.
May 27, 2008 | Acer Aspire 5100 Notebook
IBM Infoprint 6500 Matrix Printer Logo
47 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
