Question about Frigidaire GLTF1670A Front Load Washer
Help on replacing a belt
I put a new belt on and this one keeps slipping off in spin cycle.The old belt did the same thingso it was time to change it.It is 7 years old and i cant find help on the internet. Can you help please.
desperate house wife
  • maryann3608 Apr 17, 2008
    my washer is not spinning but it does empty how can I fix it?
  • Anonymous Jun 17, 2008
    Same thing here...frigidaire front loader...new belt is narrower..keeps slipping off. Does it have omething to do with the motor shaft that drives the belt> It seems to travel along there..changing the way the belt sits on the Larger drum pulley?????
    Novelist:
    Champion:
  • 261 Answers
Part 916708 is the belt I think you should be using, If you still have the belt look at the side for any numbers and compare to your purchase. I know there is a couple of belts and one is bigger.
Posted on Sep 10, 2008
Clothes do not spin as much as they used to when i use the gentle cycle It seems to spin much more effectively on the main wash cycle but I do not use this cycle much.This machine is 20yrs. and has given...
If your washer is a front loader it MIGHT be that the belt is slipping, although I would expect it to slip more on the main wash spin cycle than the gentle spin cycle! Sorry to ask but are you sure that it doesn't spin as much on gentle as it used to?
Just in case it is a belt problem, here are my guidance notes on having it changed ;-0)
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
Mar 04, 2011 | Washing Machines
My spin cycle doesn't remove all the water from the clothes so I have to run the spin cycle twice. Does this mean its probably the belt?
It depends on whether you think it is spinning at the right (fast) speed or not. Often if the wash and rinse cycles go OK but the spin does not it is the belt which is slipping.
Now- I do not know your particular machine, whether it is a front or top loader. I normally try and help with front loader problems!
Just in case it IS, what follows is my 'standard' document for the replacement of belts, copied and pasted 'cos it's quicker ;-0)
Good luck,
John C
Feb 13, 2011 | GE Profile WPSR3120WWW
Belt spins but tub won't somtimes during spin cycle
Worth going at this a bit at a time.
First look at the routing of the belt. What keeps it tight? has anything that ought to be keeping it tight worked loose?
Now take the belt off and spin the tub by hand. Does it move freely? Does it make any funny noises? Does the motion feel lumpy or gritty? This will help you decide whether you have a bearing problem or an old sock that's got where it shouldn't have.
If either of these tests hints at a problem, investigate further and fix it.
Then, regardless of whether you found or fixed anything, fit a new belt. Quite often the problem is just that as they get old, they stretch and then don't grip so tightly - and if it has been slipping because something else was loose or stuck, the heat generated will since have made it stretch anyway.
A.
May 29, 2009 | Maytag Washing Machines
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
My Magtag Performa washer has been shaking in the spin cycle very violently lately. The floor has not changed, so I can't blame an uneven floor. I'm assuming the belt may need to be tighten or replaced. ...
first I would check your drain pump.. you may have something blocking the water flow... this will cause the water not to fully drain and your machine will have a out of balance load...a loose belt will just slip and make noise,,,
there is a panel in the back you can remove to check the drain pump...let me know if this is helpful...
Sep 13, 2008 | Maytag Washing Machines
Servis washing machine belt slips off when on spin cycle
You dont stated the brand and model of your machine so all I can say is yes change the belt allways when this hapend to one of my client I change the belt becouse the belt is waring off and loose its trech condition loosing flexibility and slipping out wen ist run at high velocity....good luck and rate me....
Feb 17, 2008 | Washing Machines
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
