Question about Canon Pixma MP800 All-In-One InkJet Printer
Black print is skipping
The black print (large tank) prints sharp for approximately a 1/2 inch (2-1/2 lines) of print and then has no print for the next 1/2" and then prints beautifully again.
I replaced the print head and large black ink cartridge. No improvement.
Thanks!
David
  • depropst Apr 11, 2008
    This occurred half way through a **** of HP premium Ink Jet paper, however I just tried a piece of linen stationary and a piece of card stock with the same problem.
    Thanks! David
    The problem is not a blur. it is a repeating 2-1/2 lines of print followed by a no printing at all of the same distance. Very regular.
    Occurs in all settings, high quality to fast.
    This started a few days ago 2-3 pages into printing a document.
    Genius:
  • 3,422 Answers
Did you try runing a nozzel check?Please try out once and let me know.
goto to start-> settings->printers and faxes-> select your printer->right click->properties->tools-> find options like clean cart or nozals.
check printer settings for best ,normal,or draft set as best and try. may helpful.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 11, 2008
    Master:
  • 788 Answers
The carriage cable connecting the print head to the engine board is probably at fault. Make sure it is properly connected at both ends. Also make sure the contacts connecting the printhead to the carriage are in place, clean, and not damaged.
Sounds like only half your printheads are firing.
Do the colors print ok? It's only black?
  • Dean Joly
    Dean Joly Apr 11, 2008
    The black printhead is probably setup in two parts, each about half an inch in lenght. One of those arrays is not getting an electrical signal. I've seen this happen with the traces on the board the printheads are on got chipped and cut off from the printer. If you have a new head though the problem is in the ribbon cable, contacts in the carriage, or the engine board itself. Start with the contacts and the ribbon cable.
  • Canon Master
  • 19,396 Answers
Could be a paper problem
  • Ginko
    Ginko Apr 11, 2008
    For example if the printer is set up for standard paper and you use glossy paper the ink may blur in the middle of document, check your printer settings. Eventually see if the problem happens when you use your printer on a lower resolution settings.
    If it is not a setting and media problem, it can be a traction problem.
  • Ginko
    Ginko Apr 11, 2008
    It is the traction , it is a mechanical fault. If the printout does print empty lines at regular distance in the document, then is a problem with the traction, as the rollers are pulling paper not in synchrony with the printing job done by the heads.
    The only simple maintenance you can try on this is cleaning the rollers with cleaning solution, but I do not think this will help.
    Your printer mechanics need a partial dis-assemblage to discover were the problem is.
    Also check if you have a setting called "prevent paper abrasion" in your printer properties (it is there only on some pixma model). If it is checked un check it, it diminish the roller traction force on paper.
    If you decide to bring it to a service point out that it may be a traction problem of this kind, usually no replacement part is required for this kind of service, that therefore should not be too expensive.
    regards
Black ink is skipping lines
Take out cartridge put in a sandwich baggie and shake it; then re-install
Sep 25, 2014 | Canon PIXMA MP610 InkJet Printer
My canon pixma mp620 won't print black ink but other colors print ok.
Does printer have 2 black cartridges, 1 large 1 small? if so, the small black one and colors only takes care of the color print jobs and the large black one, the main black and white jobs. Make sure you don't have an empty large black cartridge.
Aug 15, 2010 | Canon PIXMA MP620 All-In-One InkJet...
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
May 11, 2009 | Canon i860 InkJet Photo Printer
A black line is appearing on the printed paper on all copies.
Hello.
check the Fuser unit "the two roller" .... are they clean?
Jan 12, 2009 | Panasonic FP-7735 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Canon MP830 - extreme ink useage
According to a service manual for a similar Canon printer, the grayscale printing should only use the Pigment Black ink PGI-5BK.
On fast it is 300x300dpi with 1 pass, standard is 600x600dpi with 1 pass and high is 600x600 with 4 passes.
On plain paper in colour it is meant to still only use the C/M/Y and again the big pigment black ink PGI-5BK, it only uses the smaller black ink once you set it to use a photo type paper in the printing settings.
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
109 people viewed this question
old marine
old marine
