Question about Haier Preference Plus HWR24VCA Air Conditioner
Haier Air Conductioner
This is Skinny Man again.I check the problems you said to check the other day an when I took the cover to check it out,I found a fuse that was blown,it was located on the back plate.Can I get the fuse by itself or will I have to the whole little circuit board? The number on the fuse isT3.15AL25VP.The number of the circuit board is VC532237 20N/0010403472 VOO.Help,Thanks.P.S. Where can I get the part?
  • 237 Answers
SOURCE: Water leaking from unit
It may be the drain line is not dripping into the catch bucket under the back side, visually check to see if the line is reaching into the bucket and that it's not clogged up on the inside of the unit floor. The back panel being wet may just be condensation in between cooling cycles as the frost melts. If the unit is OK with keeping temps the refrigerant charge is likely OK.
Posted on Nov 24, 2006
  • 473 Answers
SOURCE: Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Posted on Oct 06, 2007
  • 86 Answers
SOURCE: Haier a.c. will not run 24,000 btu. Window Unit.
1.voltage stabilizer.
2.selector switch.
3 check input wiring.
4 check out put wiring.
Posted on Mar 28, 2008
  • 1036 Answers
SOURCE: Haier HPRD12xc5 triangle with ! light is on and it keeps shutting off
I think this a fault with the cooling compressor.
When it cuts out aggain, turn off and unplug. See if the compressor is hot to the touch. If it is, I think it's tripping the overload protector. This is usually due to a faulty capacitor.
If you are unable to check the unit, take it to a service centre, or call an engineer to check and replace the defective components.
Hope this enables you to resolve the problem. If it does, please rate this as Fixya, or contact me again for further help.
Would you like the number of a local engineer? If so please supply your Zip code and I will contact one for you.
Posted on Jun 16, 2008
SOURCE: Where can I find the fuse on the panel? on the internet, you can purchase a 10 pack of 250volt 12amp fuses. AG-12
Posted on Aug 02, 2008
Refrigerator not cooling what is stopping it?
Does it have power? (does the light come on when you open door)
If it has power is it blowing air inside?
My fridge stopped working a few months ago. It had power but was blowing warm air. After taking the cover off the rear bottom I found the compressor was not turning on. The 'Overload Relay Switch' was burned out... I ordered/replaced (Lowes).. It cost me about $50 and took about 10min to install.. It has been working great since.
Dec 04, 2013 | Haier Convertible Bottom Drawer French...
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Can it be mounted on its side? i have tall skinny windows
NO!!! You cannot do that you will have water everywhere!!!
Click here
This is the type you need... it is called a casement window A/C
Jul 20, 2011 | Haier HWF05XC5 Air Conditioner
Haier CPN10XC9 leaking water. Have drained the
I had the same problem, removed rear cover (15 screws) and found a drain slot under the conderser plugged with dust and grime. gently cleaned the slotted area out with a Q-tip, and the condensate is now following the proper flow into the tan and evaporator. It has been running for 2 hours with no drips!!
Jul 17, 2010 | Haier CPN10XC9 Air Conditioner
How to remove plastic front to clean
I will tell you that every brand has a different way of removing the front face cover. I sell the Haier Central Heat Pumps and Air Condioners and repair window units. Click Here for the user guide=> HWR10XCA
Most fronts come off after pulling the front cover facing from the top as the bottom is sitting into clips. Most are but you removed a screw fromsomewhere and it just may be only one tha keeps it snug so the cover will remain firm. Here is a link to=> Haier America and thier contact link=> Contact Us and their=> Hot Line
AMERICA & AUSTRALIA U.S.A. & Canada All Haier Products
Hotline : 1-877-337-3639 Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services,
Thanks, Sea Breeze
May 09, 2010 | Haier HWR10XCA Air Conditioner
My Haier 8,000 BTU air conditioner is showing an 'E1' in the digital display. It won't turn on. What is the problem?
I had that same problem, find the remote and use that to turn it on / off. It solved the problem for me, for whatever reason. You will need to use the remote until the buttons start working again, took mine a few days. I have no idea what was wrong with it.
Sep 06, 2008 | Haier Heating & Cooling
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way
Defrost system problem; Check back wall of freezer for frost buildup which indicates the defrost problem.
Jun 20, 2008 | Maytag MZD2766GES Side by Side...
2.selector switch.
Mar 25, 2008 | Haier Preference Plus HWR24VCA Air...
Sep 19, 2007 | Haier HNSE05 Refrigerator With Ice Box
Haier Preference Plus HWR24VCA Air Conditioner Logo
199 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
